3201    <<    Message Index    >>    3203
Number: 3202
Date: Fri Aug 1, 2003  8:12 am
Subject: Re: Please help me I'm new!!
Thanks every one for the replys and emails. I have the motor apart
now and the motor actually works fine. The gears are locked up. I'm
in the process of filing the gear down so it will turn, it seems to
be too tight in the metal casing. I imagine extreme heat or some
other freak of nature caused this. I will update when I've solved
the problem. Thanks again.
--- In ascmclaren@yahoogroups.com, "jdawg" <jdawg@e...> wrote:
> you can use the trunk pull down motor out of a caddy. there is
also
> a switch in the trunk that prevents the 2 from being operated at
> same time, which would cause a serious bind... check to make sure
> that switch is active before you go further. i have switched my
> pull down motor out twice, the last time i went to the junk yard i
> bought 3 motors just in case.
> jdawg
--- In ascmclaren@yahoogroups.com, "gmuffb" <gmuffb@h...> wrote:
> > I just bought a 89. The top won't work. The tonneau cover will
> > release and close just fine. But the release for the actual top
> > won't work. I took the motor out. I can hear the motor running,
> but
> > the gears won't spin, so the top won't release. I really don't
> want
> > to pay $300 to have the motor rebuilt. I spoke with the man from
> > this website: www.ascmclaren.com. He wanted that much to rebuild
> it.
> > Do I have any other options??? Thank You.
