3421
3423
Number: 3422
Date: Sat Aug 30, 2003 11:17 pm
I think they are allready over there..
> OK, then I want to move that info out of the coupe paint section in
> that file and move it to the vert section.
> Do you have the vert paint codes? I could add the rest of them too.
> > Nope, they are all DIFFERENT colors. 7N "Dark Shadow Blue
> Metallic"
> > as used on ascMcLaren MUSTANGS was Ditzler Mix # 3946, on the
> > 1987/1988 ascMcLaren 2-Seat Roadsters where it was
> called "Atlantic
> > Blue Metallic". Confused, yet??
> > A different Dark Blue for each year McLaren Coupe and a still
> > different version for the '87 & '88 Mustangs!
> > S A N D Y
> > > I have listed in file "ascMcLaren Colors.txt" in the "files"
> > section:
> > > 7N > Dark Shadow Blue Metallic of 1987 & 1988 Mustang
> > > This was from one of your previous posts that I had put in the
> > files
> > > section. Is this also coupe color because you didn't list it in
> > your
> > > last post?
> > > I put the extra color info in the "ascMcLaren Colors.txt" file
> and
> > > the striping info in the "ascMcLaren Coupe Stripes and
> Logos.txt"
> > > file. Both are located in the files section. I made sure I
> added
> > > in all the interesting tidbits that weren't there already.
> <cigarsandy@c...>
> > > wrote:
> > > > Been some talk on here recently regarding paint colors for
our
> > > > beloved coupes. Post this to the Database if you'd like!
> > > > COUPE COLORS
> > > > 1984:
> > > > Ford Code 5C - "Dark Cadet Blue Metallic"
> > > > Ditzler Mix Code 3588
> > > > 1985:
> > > > Ford Code 3L - "Dark Blue Metallic"
> > > > Ditzler Mix Code 3171
> > > > Ford Code 9L - "Oxford White"
> > > > Ditzler Mix Code 3620
> > > > 1986:
> > > > Ford Code 7B - "Shadow Blue Metallic"
> > > > Ditzler Mix Code 3865
> > > > Ford Code 1C - "Raven Black"
> > > > Ditzler Mix Code 9000
> > > > Ford Code 1D - "Smoke Metallic" (Med/Dk. Grey)
> > > > Ditzler Mix Code 3842
> > > > Ford Code 1E - "Silver Metallic"
> > > > Ditzler Mix Code 3621
> > > > ascMcLaren felt the strong need to re-name a few of these
> > paints.
> > > > All 3 model-years ascMcLaren referred to the BLUE
as "Midnight
> > > Blue"
> > > > and the Smoke Metallic was called Charcoal Grey Metallic and
> > > > Silver was called Platinum Silver Metallic.
> > > > ABSOLUTELY POSITIVELY NO OTHER COLOR ascMcLAREN COUPES WERE
> EVER
> > > MADE!
> > > > It should also be noted that the Shadow Blue Metallic and the
> > > Silver
> > > > Metallic were NOT available on the EuroCoupes!! EuroCoupes
> were
> > > ONLY
> > > > available in the white, the black or the Smoke Grey.
> > > > Full Packaged Coupes offered striping and logo decals in:
> > > > "Popsicle Orange"
> > > > "Raven Black"
> > > > "Platinum Silver"
> > > > IF IF IF IF the ordering dealer did NOT specify the color for
> > > > decals, ascMcLaren installed the Popsicle Orange on the blue,
> > grey
> > > > and white cars. The Raven Black cars got the Platinum Silver
> > > > striping/logos and the Platinum silver cars got the Raven
> Black
> > > > Striping.
> > > > However, dealer/customer could order ANY stripe color on any
> > paint
> > > > color by making THAT known. I have located a couple of Raven
> > > Black
> > > > cars with the Popcicle Orange striping and a Smoke Metallic
> car
> > > with
> > > > Platinum Silver Striping as well as an Oxford White car with
> > > Platinum
> > > > silver Striping. Have also located a F.P. car with NO
> striping,
> > > nor
> > > > logos EVER, and a handful of blue cars with Platinum Silver
> > > striping.
> > > > S A N D Y
