3708
3710 Number: 3709 From: "negusm" Date: Sun Oct 5, 2003 3:41 pm Subject: Re: [ASC McLaren ] Underhood Light
I am looking at the 89-93 Engine Compartment from the "Late Model Mustang Illustrated Parts Catalog (page 186) and it doesn't show any button but just shows the bulb with a module (#15702) and the wires that go down to the fire wall. This module appears to detach from the wiring harness and can be replaced.
I would use a voltmeter to see if there is any voltage going into the module first. It is always possible that the problem is not the switch. And I have my doubts as to how a mercury switch would wear out. I was under the impression that they generally are good for eons.
But if it is the module, just ask the dealership if they can get the part. They can search nationally for it. However, it may no longer be available and sometimes www.PartsVoice.com kicks back a parts house that has one.
I "guessed" at the complete part number "E9ZZ15702A" and typed it into www.partsvoice.com. One listing was returned:
ED BENNETT FORD PARTS
Address: 9 SCHOOL LANE LEBANON PA
National Phone: None Business Phone: 717-272-8762 Email: edbfordparts@i...
This would be a new part but make sure the dealer confirms the part number I "guessed" at.
Thats all the info I have.
--- In ascmclaren@yahoogroups.com, "Sandy Block" <cigarsandy@c...> wrote: > How expensive is this to fix? > Looking at it - I realize that you must be correct. Since I have the > silver one (also a 90) I checked it. The light does not come on > until the hood is a good 3 feet raised from the closed posistiom - > certainly NO little switch is that high. "Mercury" sounds costly. > Can't buy a junk yard as there's no guarantee that IT will work! > > "S" > > > >
--- In ascmclaren@yahoogroups.com, Tom G <speedracer815@y...> wrote: > > Sandy, I don't believe there is a button for the > > underhood light. I know in later years they went to a > > "mercury switch" that simply senses the tilt of the > > hood and turns on. It's incorporated into the bulb > > holder itself on my '96. > > > > Tom > > > > > > __________________________________ > > > > The New Yahoo! Shopping - with improved product search > > http://shopping.yahoo.com
