3730
3732
Number: 3731
Date: Tue Oct 7, 2003 2:33 pm
Subject: Re: Underhood Light
Re: Underhood Light
I'm sorry try using this pic as a better reference to what I mean...
Try bending the switch (black arrow) in the directions of the red
arrows...tweak it til it goes on (if it does) then make sure it goes
off when the hood closes...hope THIS helps...make sure to copy the
whole link because yahoo wraps long URLs and it might get messed up...
http://mywebpages.comcast.net/n20capri/MikeNewWeb/images/Switch.jpg
> I wiggled the housing around a bit & it seemed pretty darn tight.
> compared it to the silver car, and the blue car is identical.
> The "bad" bulb illuminates when installed in the silver car, as do
> all of the bulbs, when istalled in the silver car. NONE of the 3
> work in the blue car.
> -- In ascmclaren@yahoogroups.com, n20capri <no_reply@y...> wrote:
> > Sandy,
> > Try adjusting the light itself...if the housing is at the wrong
> angle
> > it will not work. The angle has to be correct for gravity to
take
> > it's effect on the mercury and make the connection when the hood
is
> > opened...
> > My friend got an auto start for her car so she could remotly
start
> > the car in the winter and it wasn't working...I traced it to the
> > mercury switch under the hood...The system will not work if the
> hood
> > is open and the mercury switch was telling the system that it was
> > open...what happened was they mounted it in the wrong place and
> when
> > the hood was closed the switch was hitting something under the
hood
> > and bending...So I had to remount the switch and set the angle
> > Presto...it worked...
