3750
3752
Number: 3751
Date: Thu Oct 9, 2003 7:27 pm
Subject: Re: Tonneau pull down
Jeff is 100% correct and I need to add the "fix" ~
Get a faucet washer, small, smaller than a dime. On the flat
surface, put a piece of double sided tape, and stick it on the button
you pushed in. This will build the buttom out and it will make
better contact with the trunk's hinge arm.
--- In ascmclaren@yahoogroups.com, "Jeff Burgy" <cobrajeff@c...>
> There is an interlock switch with a pushbutton on it on the left
> trunk lid hinge. This switch prevents you from opening the trunk-
> lid and the tonneau cover at the same time. When mine went out of
> adjustment, it acted like yours - the power pull-down (and power
> release, too) would not work. I had to maually release and latch
> the tonneau until I fixed the adjustment.
> You can test this easily - with the trunk open, push in the plunger
> of the interlock switch, then have someone else push the button on
> your top pull-down - if it works while you are holding that
plunger,
> that is the issue (be careful to NOT open the tonneau fully while
> the trunk is open - they will hit each other).
> Hope this helps.
> regards,
> Jeff Burgy
--- In ascmclaren@yahoogroups.com, "papetalu" <pmorrow.etal@w...>
> > I've got an '86 McLaren. The tonneau has ceased to pull down on
> its own.
> > (I've never had to push the switch down, as the pull-down
sequence
> was
> > triggered by pushing down on the tonneau like A Caddy trunk).
> > Consequently, I have hot-wired the battery off my cordless drill
> with
> > alligator clips to bypass the wiring to the motor and get the top
> > secured. The motor is fine. The relay seems OK as I have
manually
> > operated the points to try and remedy the situation. Does anyone
> have
> > a wiring diagram for this system? I fear I have a short, but am
> not
> > sure of what wires should be hot and where they terminate.
Thanks.
