3759
3761
Number: 3760
Date: Fri Oct 10, 2003 8:26 pm
Subject: Re: [ASC McLaren ] got my car!! a few q's...
wow....thanks for taking the time Marq --unfrotunately.... I'm
referring to the fit when the top is up(!) it's tight around the
sides of the car - is this normal?? I'm sorry I wasn't clear and I
made you write all that but I really appreciate it... If you have any
ideas about my problem now (or if that's just the way it's supposed
to be), I'd appreciate it (again). Thanks alot Marq, you're the man-
Jermey
> I am still having a hard time visualizing how that cover hatch
could leave so much of a gap that you could poke your fingers
through. Seems very odd.
> If the gap is prominently at the back section of the hatch, where
it almost comes in contact with the rear trunk lid, then possibly you
should check how the hatch mechanism 'hold down' is bolted into
place.
> There are three areas where you can make adjustments to the fitment
of the hatch cover. The first two are the ones located nearest to
the door pillars. Those ones tend to give you back and forth
adjustments. HINT : Don't go too far back with your adjustments or
it will snare the trunk lid and be a 'b*tch' to open. When
I 'accidentally' did that myself, I had to pop open the trunk in
order to unsnare the hatch piece.
> The other adjustment point is where the hatch actually locks
down. It is the mechanism that engages when you go to pop open the
hatch. On my silly car there is just a wire leading to it. I don't
know what it is suppose to look like on an untainted McLaren. It
looks like a trunk latch mechanism - but we are not talking 'in the
trunk' here - this one is located where the hatch cover clicks
down. This one can be adjusted to give up and down positioning to
the hatch cover. It almost seems like this is the one you are
talking about for being able to slip fingers into the car's
compartment.
> In one last clarification, I hope we are not simply talking here
about the way the rag tog fits on to the hatch cover. The
adjustments that I have been talking about all concern the hatch
cover that hides your rag top under it when it is down.
> Oh...and while I am babbling here. What I was trying for when I
made the adjustments to my hatch cover was to get a 1/8th inch gap
along the sides of the car and across the back area of the hatch
cover where it lines up along side the trunk lid.
> To complete my adjustments I had to make adjustments also to the
way the trunk lid was put on. The two hinge arms that hold the trunk
lid in place, each have two adjustment bolts on them. By loosening
those bolts slightly you can draw the trunk lid closer to the hatch
cover or back it off. Also, because of the way the trunk lid arms
are angled, it also affects the height that the trunk lid lines up
against the rear quarter fenders.
> Mostly it is just a game of fidgeting with the bolts and
adjustments until you reach the best possible positioning of the
parts. I was able to get a 1/8th inch fitment to the trunk lid and
the hatch cover.
> I assume that somewhere in my poor car's history, they had
physically removed all these parts during their attempts to rebuild
it ( or whatever they attempted to do ). When they went to re-
install the parts they appeared to just slam the parts back together
with not much attention to the proper fitment.
> Anyhow, hope this gives you some ideas on what to poke around with.
> Marq
> From: jeremymccurdy
> Sent: Wednesday, October 08, 2003 9:22 AM
> Yes, the rubber seal is still in place - it just doesn't seal
flush
> to the body; I can slide my fingers under it into the car from
> outside- maybe this weekend I'll see if I can adjust it...
