3761
3763
Number: 3762
Date: Fri Oct 10, 2003 11:05 pm
Subject: Re: [ASC McLaren ] got my car!! a few q's...
Three variations. 1987 / 1988 / 1989&1990 = 3
I have never been able to find out who the original manufacturers of
them were. I will never give up.
Atlantic Blue / Black / Tan / Claret~Wine / Dark Brown / Oxford
White / All were Cambria Cloth, except the Oxford White, which was
Bayville Vinyl.
> Ok.... I am still not getting a clear picture on this. That
fitment info I gave would cover that hatch area, whether it is up or
down.
> Now I am not sure, but I believe you are referring to the potential
gaps that may occur between :
> a) the ragtop and the top part of the driver and passenger window,
or
> b) the side of the ragtop and where it almost comes in contact with
the body of the car, directly behind each of the driver and passenger
windows, or
> c) where the back of the ragtop comes in contact with the rear
hatch cover....
> For A and B, on my car, there is a gap that I could conceivably
push my fingers through. But it sufficiently overhangs the window so
that water would be thrown out and beyond the window. Similarly in
the B position, there is also a bit of a gap that would permit me to
put my fingers through.
> In both the A & B scenario, I think this is normal for the way the
McLaren ragtop was designed to fit on these cars. And possibly with
some age shrinkage it might even become a little more pronounced.
> In the case of C, I think that is where the best 'sealing' of the
ragtop occurs and there should be no light or 'space for putting
fingers through.
> I do not know if the rag on my McLaren is the original rag or a
subsequent replacement unit. I almost suspect that it is a
replacement ragtop, simply due to the absolutely horrible manner in
which the entire car was maintained.
> So... what I am seeing may be typical of an aftermarket ragtop (
whose source of origin is unknown ). But from what I gather, even
within the various model years of Mc, there appears to be at least 2
official styles of genuine Mc ragtops ( not including the various
colors or material - I am just referring here to the way the tops
were cut and pieced together ).
> At this point Sandy could probably step in and give us the official
word on how many 'genuine' variations on the officially supplied
McLaren ragtops there were altogether.
> Marq
> From: jeremymccurdy
> Sent: Friday, October 10, 2003 8:26 PM
> wow....thanks for taking the time Marq --unfrotunately.... I'm
> referring to the fit when the top is up(!) it's tight around the
> sides of the car - is this normal?? I'm sorry I wasn't clear and
> made you write all that but I really appreciate it... If you have
any
> ideas about my problem now (or if that's just the way it's
supposed
> to be), I'd appreciate it (again). Thanks alot Marq, you're the
man-
> Jermey
> > I am still having a hard time visualizing how that cover hatch
> could leave so much of a gap that you could poke your fingers
> through. Seems very odd.
> > If the gap is prominently at the back section of the hatch,
where
> it almost comes in contact with the rear trunk lid, then possibly
you
> should check how the hatch mechanism 'hold down' is bolted into
> place.
> > There are three areas where you can make adjustments to the
fitment
> of the hatch cover. The first two are the ones located nearest
> the door pillars. Those ones tend to give you back and forth
> adjustments. HINT : Don't go too far back with your
adjustments or
> it will snare the trunk lid and be a 'b*tch' to open. When
> I 'accidentally' did that myself, I had to pop open the trunk in
> order to unsnare the hatch piece.
> > The other adjustment point is where the hatch actually locks
> down. It is the mechanism that engages when you go to pop open
> hatch. On my silly car there is just a wire leading to it. I
don't
> know what it is suppose to look like on an untainted McLaren.
It
> looks like a trunk latch mechanism - but we are not talking 'in
> trunk' here - this one is located where the hatch cover clicks
> down. This one can be adjusted to give up and down positioning
> the hatch cover. It almost seems like this is the one you are
> talking about for being able to slip fingers into the car's
> compartment.
> > In one last clarification, I hope we are not simply talking
here
> about the way the rag tog fits on to the hatch cover. The
> adjustments that I have been talking about all concern the hatch
> cover that hides your rag top under it when it is down.
> > Oh...and while I am babbling here. What I was trying for when
> made the adjustments to my hatch cover was to get a 1/8th inch
gap
> along the sides of the car and across the back area of the hatch
> cover where it lines up along side the trunk lid.
> > To complete my adjustments I had to make adjustments also to
> way the trunk lid was put on. The two hinge arms that hold the
trunk
> lid in place, each have two adjustment bolts on them. By
loosening
> those bolts slightly you can draw the trunk lid closer to the
hatch
> cover or back it off. Also, because of the way the trunk lid
arms
> are angled, it also affects the height that the trunk lid lines
up
> against the rear quarter fenders.
> > Mostly it is just a game of fidgeting with the bolts and
> adjustments until you reach the best possible positioning of the
> parts. I was able to get a 1/8th inch fitment to the trunk lid
> the hatch cover.
> > I assume that somewhere in my poor car's history, they had
> physically removed all these parts during their attempts to
rebuild
> it ( or whatever they attempted to do ). When they went to re-
> install the parts they appeared to just slam the parts back
together
> with not much attention to the proper fitment.
> > Anyhow, hope this gives you some ideas on what to poke around
with.
> > Marq
> > From: jeremymccurdy
> > Sent: Wednesday, October 08, 2003 9:22 AM
> > Yes, the rubber seal is still in place - it just doesn't seal
> flush
> > to the body; I can slide my fingers under it into the car
from
> > outside- maybe this weekend I'll see if I can adjust it...
