3777    <<    Message Index    >>    3779
Number: 3778
Date: Sun Oct 19, 2003  12:42 am
Subject: Re: horn and head lights
thanks everyone... as for the whole horn deal i do have a nice size
kink in it... and for the fog lights... i dont have any... and i dont
see any wires where ones would go ill go to the parts store on monday
and try and get a new switch ill let you guys know if it works or not
thanks all agen...
> Replace your headlight switch. Your symptoms are typical. This
> question gets asked every other week on the other message boards.
> I bet if you put it on high beams its really bad.
> There is a breaker in the headlight switch unit that goes bad.
Just
> unscrew the black plastic bezel thingy around the headlight pull-
> knob. That will loosen the unit up from the dash. There is a
> little metal button on the unit which if pressed the knob and shaft
> should pull straight out. You may have to twist the knob around a
> bit. Then unplug the unit and replace with a new unit.
> First time it happened to me was at 10:30pm coming back from Skiing
> in the mountains. Whenever I clicked on my high beams, after a few
> minutes the lights would black out for 2-3 seconds. I finally got
> smart and left them on low beams all the way home.
--- In ascmclaren@yahoogroups.com, "tfs2121" <tfs2121@y...> wrote:
> > im not sure why but randomly my horn will stop working the only
> > sound i will hear is a clicking under the dash it comes back and
> > goes out once in a while like once a week each...
> > also as im driveing at night my head lights will flicker on and
> off
> > anywhere from half a sencond to up to 2 or 3 senconds the
interior
> > or dash lights stay on and it happens with both brights and
normal
> > lights
> > its an 85 capri mclaren h/b
> > any help would be amazing...
> > ~Peter
> > p.s. i have tryd pulling and twisting on every wire under the
hood
> > with the lights on and im am still yet to get them to go out my
> dad
> > thinks it might be the intirior switch let me know
3779 Re: horn and head lights ecstacycustomz ecstacycustomz Sun  10/19/2003
