3943    <<    Message Index    >>    3945
Number: 3944
Date: Thu Nov 13, 2003  3:26 pm
Subject: Re: To: Mike
Re: To: Mike
'Ya, I am bored, you are correct. Gettin gover being sick, and well
enough to want to go out, but still way too tired. Need 70 degrees
and a car to wax!!!
> You must be bored. Only you would find that :-)
> I also changed where it says "(GM85:99)" to "(GM85:79)" in the same
> paragraph.
> > Black Cherry Pearl is actually from Cadillac (1985-87) where it
was
> > called "Bordeaux" (Code 99).
> > NO NO NO!!! It's code 79 !!!!!!!!!!
<cigarsandy@c...>
> > > Mike, I discovered my error. Go here:
> > > http://f1.grp.yahoofs.com/v1/kLizP0UUeuc6jvFsnj1wVTDL-
y7VdcUNTBPpKghOohIuGoJDt7JLuD5B6kOI14t8IE2wmBKAiUcWRG7lxn1xSN8h7FuEZBR
> > > e/ascMcLaren%20Colors.txt
> > > Under Exerior colors: Anecdotes and about the 6th or 7th
> paragraph
> > is
> > > talks about BLACK CHEERY being a Cadillac color & says it's
code
> > > 99. That's wrong. It's Code # 79. Could you fix this??
