3964    <<    Message Index    >>    3966
Number: 3965
Date: Tue Nov 18, 2003  11:12 am
Subject: Re: [ASC McLaren ] Re: Popular Info for COUPE shocks
Or as James just put it better............"Sales & Marketing" :)----- Original Message -----
Sent: Tuesday, November 18, 2003 11:09 AM
Subject: Re: [ASC McLaren ] Re: Popular Info for COUPE shocksMike,
Sure they used off the shelf parts, but asc/Mclaren did choose these parts
specifically for use in the car. :)
I would call it "Sales Propaganda", it sounds impressive to the average
consumer who doesn't know better.
Remember Ricardo Montalban selling "Rich Corinthian Leather" to the masses
in the 70's & early 80's?
Bushing Durometer is a measurement of the density or stiffness of the item
in question. In this case the suspension bushings were replaced or
substituted with one with a higher rate. In other words they installed
stiffer bushings for less deflection in the suspension and better handling
performance.
Brent
Sent: Tuesday, November 18, 2003 10:45 AM
Subject: [ASC McLaren ] Re: Popular Info for COUPE shocksAbout the springs....
Previously, it has been stated that on the coupes asc would "Employ
MCLAREN Specific Damper Units & Springs to achieve better cornering &
a softer ride than the TRX System from Ford." I assume that Sandy
has pulled this from a memo somewhere.
It sounds that the reality is that McLaren had nothing to do with
this. Everything seemed to be off the shelf stuff:
T-Bird tie rod tips
Carrera Shocks
M-5300-C Motorsport Spring Kit
Increase Suspension Bushing Durometer
Also, weren't the springs specially designed by asc? So how could
they be in a Motorsport kit.
Just a bit confused. My ignorant statement of the day: What is a
Bushing Durometer anyhow?
> Okay, it uses the following:-
> SHOCKS:-
> Carrera Shocks {brand}
> They are located in Georgia (I believe the town is NORCROSS)
> If they have not changed their area code or tele. #
> they are at: 1-404-451-8811
> The casing on the front shocks is either white or gold, it makes no
> difference.
> The rear shocks are chrome encased. The part # for the rears is:
> 3698.
> They are adjustable 3 ways. I was never supplied with a FRONT
shock
> SPRINGS:-
> They employed the Ford Motorsport "SUPER-SPORTS" Spring Handling
> Kit. This
> has to be ordered thru a Ford MotorSport Dealer. The Kit # is:- M-
> 5300-C.
> If you'll write back & give my your home state, I'll give you the
> names of a
> couple of Ford Dealers that are certified Ford Motorsports Dealers.
