3994
3996
Number: 3995
Date: Sat Nov 22, 2003 2:12 pm
Subject: Re: asc Coupe Parts
Re: asc Coupe Parts
Not as far as I know.
I would think you should be able to disassemble the compressor and
get rid of the rust and oil it up really well. They are very simple
inside with only a few moving parts. However, if the wires that
make up the motor have shorted, then it may be a goner.
If those wires are messed up, you can buy wire wrap (people wrap
their own electrical motors in various hobbies, same stuff is
probably used in speakers too) and rewrap it.
Or just buy a new air horn kit which will have a compressor very
similar to the original and reuse your original air horns.
--- In ascmclaren@yahoogroups.com, "tfs2121" <tfs2121@y...> wrote:
> the one that i took off my car is the one on the right but when i
> opend it up its all rusted solid... i thought thats what i was
> hearing this whole time but i guess its the electric ones mounted
in
> my fenders
> ~Peter Shear
> ps
> is there like a re build kit?
> > http://www.ascmclarencoupe.com/ascParts/
> > Check out this page...I have taken pics of alot of the correct
> parts
> > for the ascMcLaren Coupe.
> > The air horns are pictured there. I never had the original
> > compressor but the air horns survived and are in the first pic.
> > The next two pics showed an Anes air horn kit which is almost
> > identical (except for the compressor) to the ones found on the
> > coupe. The Anes compressor is nearly identical to correct one
> > except it does not have "Stebel Junior" stamped on it and it has
a
> > yellow oil inlet.
http://www.ascmclarencoupe.com/Projects/AirHorns/compressors_top.jpg
> > The one on the right is the correct compressor.
