4053    <<    Message Index    >>    4055
Number: 4054
Date: Tue Dec 2, 2003  10:52 pm
Subject: Re: 85 coupe questions
My 85 coupe (and alot of others) have the 85 MPH speedo. It was a
hit or miss thing in 85.
I don't know about my tach...never checked it.
My car also came with the single "Y-Pipe" exhaust that was standard
that year for that car. I firmly do not believe that my car ever
had duel exhaust. There was every sign that the drive train was
never touched in that area. Your car only helps confirm this for
me. You would need to scrounge another 85 V8 YPipe system in a jy
to put it back since that was the only year they had it and Ford
does not have those parts available anymore. Or for better
performance and probably cost get the double hump for now.
The tie rod tips would be a Ford item from the TBirds of that era
that had a turbo engine. But its a good question on the year, I
don't know if there were any changes during the years for that car.
The tires you list should be correct. Asc went with very low
profile tires. When I got my car I think they were wearing:
P225 60 R15
Which are higher and make your speedo off.
--- In ascmclaren@yahoogroups.com, "tfs2121" <tfs2121@y...> wrote:
> ok so i read over the info in the files section...
> 1 my car has no 140 speedo mine goes up to 85
> 2 if the rev limit was incresed to 7000 RPM why does my tach red
> line at 5400 RPM
> also i took my care in for some repairs on the exhaust (it fell
off
> cuz of the speed bumps at my school are so huge if i barly roll
over
> them it scrapes everything) the other day and my car curintly has
a
> true dual exhaust but i have a single hump trans cross member so
> one of the pipes was crushed to clear the cross member on the no
> hump side. he says i have the wrong size tires on it and that the
> car is rideing to low to the ground and that the fact that my rear
> shocks are shot has nothing to do with ride hight(that part is
> true). the guy told me to buy a dual hump cross member and he will
> build me a system that will fit up nicely under the car... id like
> to know if the car origanly came with a dual hump trans cross
member
> and a ture dual exhaust or if it had a Y pipe after the headers
then
> a cat then another Y pipe
> are the corect size tires P225/50x15 VR-Series? (for the 85 coupe)
> about the thunder bird turbo tie rod ends what year thunder bird
did
> they come from? or is thunder bird turbo a company name...
> thanks for helping clear up some questions its a new suprize every
> day with this car you never know whats next!
> ~Peter Shear
4055 Re: 85 coupe questions Sandy Block cigarsandy Tue  12/2/2003
