4147
4149
Number: 4148
Date: Thu Dec 11, 2003 8:53 pm
Subject: Re: [ASC McLaren ] 85 coupe questions
Just a quick note here. Hopefully you havn't found out already but the 85
headers are different in length from 86 and up. You need to change them for
the h-pipe to line up correctly.
Oh and don't gut the cat. You are correct in saying that it creates
turbulence. Besides what you may wan't to do is ice the original exhaust in
a nice dry closet somewhere just in case you ever wan't to return to stock.
HTH
John (3 ASC's)
Sent: Wednesday, December 03, 2003 9:34 AM
Subject: Re: [ASC McLaren ] 85 coupe questions> Jason,
> I installed a 2-1/2" Dynomax cat-back system (#17456) on my '86 EuroCoupe
> and it cleared the rear valance without any problems.
> In 1985, there wasn't any resonator from the factory, just a single cat,
> the two mufflers.
> Brent
> From: "capri_16t" <capri_50@m...>
> Sent: Wednesday, December 03, 2003 6:21 AM
> I have mostly 2 -1/2 cat back systems on my other 5.0's. Is their
> enough room through through the Mclaren cut-outs in the back for the
> 2 -1/2 pipes to lay (without hitting) or should I go with 2 - 1/4...
> I was almost tempted to just "gut" the converters out. I crawled
> under the car yesterday and from what I have seen, these look REAL
> easy to gut out as it unbolts in several places. Anyone ever did
> this on the 85...??? We use to do this on the 86's years ago before
> people made off-road H-pipes for them. One gentlemen years ago gave
> me some interesting info on certain cats being "gutted." He stated
> that if the cat was REAL big, gutting it MIGHT hurt performance
> because what you have done is created a large open space in the
> exhaust system where air will circulate around instead of flowing
> freely through the system. In theory, I do understand his logic. But
> I know the 86 -> H-PIPE has SMALL converters so I do not think that
> logic would apply to those H-PIPE's, but the 85 does have a pretty
> big converter in the middle. Any suggestions or experiences from
> anyone????
> Also does the 85 have a resonator or something on the passanger
> side, but not the drivers side? I thought I noticed something like
> this when I was under the car, but it was cold and didn't want to
> keep my ass on the pavement for long.
> Thanks,
> Jason (88 Mclaren, 85 Mclaren)
> > My '85 was exactly as you describe.
> > 85 speedo, Y pipe exhaust which was standard that year on the 5.0,
> same tach
> > and tire size. Exhaust is easy, just get a dual hump X-member, add
> the '86+
> > H-pipe assembly and your preferred cat back exhaust and that's it.
> Headers
> > were also unique for '85 and I'm pretty sure if you leave the heat
> riser
> > valve intact on the passenger side the '86+ H-pipe will bolt right
> up.
> > Tom
> > From: "tfs2121" <tfs2121@y...>
> > Sent: Tuesday, December 02, 2003 9:31 PM
> > Subject: [ASC McLaren ] 85 coupe questions
> > ok so i read over the info in the files section...
> > 1 my car has no 140 speedo mine goes up to 85
> > 2 if the rev limit was incresed to 7000 RPM why does my tach red
> > line at 5400 RPM
> > also i took my care in for some repairs on the exhaust (it fell off
> > cuz of the speed bumps at my school are so huge if i barly roll over
> > them it scrapes everything) the other day and my car curintly has a
> > true dual exhaust but i have a single hump trans cross member so
> > one of the pipes was crushed to clear the cross member on the no
> > hump side. he says i have the wrong size tires on it and that the
> > car is rideing to low to the ground and that the fact that my rear
> > shocks are shot has nothing to do with ride hight(that part is
> > true). the guy told me to buy a dual hump cross member and he will
> > build me a system that will fit up nicely under the car... id like
> > to know if the car origanly came with a dual hump trans cross member
> > and a ture dual exhaust or if it had a Y pipe after the headers then
> > a cat then another Y pipe
> > are the corect size tires P225/50x15 VR-Series? (for the 85 coupe)
> > about the thunder bird turbo tie rod ends what year thunder bird did
> > they come from? or is thunder bird turbo a company name...
> > thanks for helping clear up some questions its a new suprize every
> > day with this car you never know whats next!
> > ~Peter Shear
