4371    <<    Message Index    >>    4373
Number: 4372
Date: Sun Jan 25, 2004  10:31 am
Subject: Re: [ASC McLaren ] Re: New Owner of a McLaren
Peter,
Thank you  for the battery information. Just my luck to be disconnecting the wrong (+) terminal. I will take your advice and go get the in-line disconnect for the negative side of the system. I think I can get this gadget at AutoAdvance.
Thanks for the note about possible messages. So far that has not occurred, but I shall take your advice. If it's sending messages and relearning, anytime now it I expect it to send:"Where/when the hell did you learn to drive?"
Thanks again,
Dick
Sent: Sunday, January 25, 2004 10:28 AM
your friend is kinda right computers were designed to
not only run the fuel injectors and read all of the
cars sensors but to learn the driver... the computers
memory is erased everytime you un plug the battery. if
you run it for a bit you might see the check engine
light come on and a code would be stored about
something like "battery dead or memory erased" your
not harming the car at all though the only thing your
doing is makeing it re learn to your driveing. dont be
worried your fine
just always remember disconect NEGITIVE b4 positive
and reconect POSITIVE b4 negitive (your really only
have to be pulling off your negitive cable they also
make screw nobs to go between the terminal and the
cable just un screw and re screw as needed)
__________________________________
Yahoo! Groups Links
4373 Re: New Owner of a McLaren Peter Shear tfs2121 Sun  1/25/2004
4374 Re: New Owner of a McLaren Sandy Block cigarsandy Sun  1/25/2004
