4403    <<    Message Index    >>    4405
Number: 4404
Date: Tue Jan 27, 2004  1:32 am
Subject: Re: door swap
Re: door swap
Oh, ya ~ your are wrong!
ascMcLaren used the doors from (for) a T-Top ! Yes, hatchback doors
for a car to be made with T-Top. Actually ascMcLaren did nothing,
FORD DID IT and they arrived at Autry Avenue in Livonia that way! 2-
Door Sedan (Coupe) wearing Hatchback T-Top Doors. {I have pictures} !
> The doors on a 85 Mustang are the same as the Capri. The holes,
> wiring, etc, should all the the same. On my car I had a Mustang
> door swapped with the Capri door and there was no difference. Yes,
> you need to move the glass and stuff over.
> Now, the doors on an 85 Mustang CONVERTIBLE may not be exactly the
> same. asc cut the window frame off the door when they did their
> conversion. They may also have done a few other modifications. An
> 85 GT convertible would have doors modified by Cars & Concepts and
> doubt they cut the window frame off in the same way as asc. I
THINK
> they also added some door bumpers to keep the fit of the door tight
> against the body so that flexing or warping would be minimized.
> However, as I've never seen an asc vert door or a Mustang vert
door,
> a Mustang vert door may actually be less work if you find a good
one.
> Some people at www.foureyedpride.com have taken hatchback/notchback
> doors and converted them to vert doors by trying to follow what CC
> did. It was work but they have been successful.
> As always correct me if I'm wrong.
--- In ascmclaren@yahoogroups.com, "merstang85" <erndog02@e...>
> > Hi I was curious if anyone has tried to swap doors between a 85
> > Mclaren convert and a 85 GT stang. I know the windows would need
> to
> > be exchanged and some trim. Are there any issues with the wiring
> > harness, both have power locks and windows.
> > P.S. Sandy Only the cat.
4405 Re: door swap Sandy Block cigarsandy Tue  1/27/2004
4406 Re: door swap negusm negusm Tue  1/27/2004
4407 Re: door swap Sandy Block cigarsandy Tue  1/27/2004
4408 Re: door swap Tom G speedracer815 Tue  1/27/2004
