4474    <<    Message Index    >>    4476
Number: 4475
Date: Thu Feb 12, 2004  1:21 am
Subject: Re: [ASC McLaren ] Re: Mclaren Coupe Specifications
The way they rated hp not only changed in '72, but new emission rules went into effect as well. Drops in compression ratios to lower NOx emission played as big of a part in the lower ratings as did the way they were rated. The base 302 in 1971 had 210hp/296tq and a 9.0:1 CR. For 72 the CR was dropped to 8.5 and was rated at 140hp/242tq... A 33% difference in HP and 19% difference in torque. Compare that to the 351CJ (not the Boss), which had the same 8.6 CR in both 71 and 72. The 71 351CJ had 280hp/345tq and in 72 248hp/290tq... 11% change in hp and  16% in torque. The lower compression ratios made a huge impact.
Sent: Wednesday, February 11, 2004 7:58 PM
BTW, pre '73 (or thereabouts) engines were rated at gross horsepower, without
most engine accessories and open exhaust.  Thereafter, engines were rated at
net horsepower, with all the accessories bolted on and full exhaust, resulting in
much lower power ratings for the same engines.
I vaguely remember the legendary Chevrolet LS6 454 rated at 450hp GROSS and
subsequently rated at ~365hp NET when the new rating system came into effect.
Nelson
1990 Mustang LX 5.0
http://fiveoh.homestead.com
http://home.comcast.net/~lxfiveoh
Sign up at 5-0.org!  http://www.5-0.org/forums/profile.php?mode=register&ruid=39
Sent: Wednesday, February 11, 2004 10:12 PM
Subject: [ASC McLaren ] Re: Mclaren Coupe Specifications
Hey Sandy, Whay's the difference in a 5.0 and a 302? My 82 has a
5.0....thought it was the first year they came back in Ford cars?
Have a 1969 Falcon Wagon... factory 302, automatic, came from factory
with 220 rated HP.....WHEN they came back in 82.....the BIV came from
factory with a 5.0HO with a whopping 157 rated HP! BOTH came stock
with 2V.......GO FIGURE!......the 69 has stock 10:1 flat top pistons
and the 82 I think has 8.5 comp.........
> The figures I posted came directly from ascMcLaren literature!
> Now, that said I will (once again, sorry to those who have heard
it)
> explain the Cam.  First off, you have to turn you mind all the way
> back to 1984.
> ascMcLaren knew the buyer to whom the car would most appeal.  They
> also knew that said buyer - in most cases (Sandy Excluded) would
> modify the car with add on "go-faster" goodies.  To this end,
> ascMcLaren requested a higher performance cam, be installed by
> ascMcLaren.  Ford said so doing will void the warrantee.  Internal
> engine work, 'ya all know.......
> So, very quietly without any ado and no advertising, FoMoCo late at
> night (sorta speak) installed the only one they had at the time
that
> would work well, the B-303.  It was felt that with the upgrades the
> average owner would select (hopefully from Ford MotorSport
Division)
> that the B-303 would be very happy.
> In-House, they referred to it as a "Blank Canvas enhancement" ~
> ascMcLaren then did the springs/shocks/tie rod tips up grades.  It
> was a cosmetic package, with a little kick in the butt, and a grin
> and a nod to those who wanted to ... ahhh..... we'll say continue!
> Now regarding racing those other cars.  They are much lighter &
> smaller and have a big advantage in weight to power ratio.  Like I
> said, you have to "Think 1984."  We had just come out of the gas
> lines and 4 & 6 cyl. was all that was out there.  It was a dawn, a
> new beginning.  The 302 block had just come back at Ford in 1983,
> was de tuned for maxi fuel mileage.  It was NOT 2000 or 2003 with
hot
> cars all over.  Your friend at school were watching their mobiles
> going around in their crib at the time.  They have no clue as to
> where we had been, prior.  It was a case of we had to crawl, before
> we could run.  These cars were at the "walking" stage, surpasing
> crawling, but not yet running!!  They are looking at your car as
> though it is/was a 2002 Camaro Z-28 SLP or a Rouch Mustang.  It
ain't!
--- In ascmclaren@yahoogroups.com, Peter Shear <tfs2121@y...> wrote:
> > this sucks! my car seems so much faster then that 6.83
> > time my friend drives a 92 Eclipse GSX (turbo AWD) he
> > says that he will beat me :(
> > i guess my thoughts of my car being one of the fastest
> > at my school is wrong (i always thought id put up a
> > good fight agenst the 97 Cobra an the 2004 350Z and
> > the eclipse)
> > anyways i wish there was a real spec like with the cam
> > and all the coupe engine upgrades
> > ~Peter Shear
> > __________________________________
> > > Finance: Get your refund fast by filing online.
> > http://taxes.yahoo.com/filing.html
