4481    <<    Message Index    >>    4483
Number: 4482
Date: Thu Feb 12, 2004  3:52 pm
Subject: Re: [ASC McLaren ] Coupe Rocker Panel and rear Cover installation
Mike,
My cars rocker panels are in poor shape and I removed them before they
worsened and were un-repairable.
They had some sort of adhesive on them along with the two screws. By
appearance and the pattern it was applied it looks like a "Liquid Nails"
type construction adhesive, I'm sure it was sort of automotive equivalent
that was used back then.
If I were in your shoes, I would get some of the 2-sided tape that almost
all of the ground effects kits today use, it is very effective and much
cleaner to use than an adhesive in a tube.
I don't know if anything other than screws were used to attach the rear
valance (it's still on my car) but I was going to re-installing it I would
again use the 2-sided tape as well as the original screws. I think the tape
would help keep the valance material from "warping" over time.
Brent
Sent: Thursday, February 12, 2004 3:28 PM
Subject: Re: [ASC McLaren ] Coupe Rocker Panel and rear Cover installation> Are you talking about the belt mouldings put on by Ford? Yeah I know
> all about those. I have NOS ones to go on.
> I was talking about the asc rocker covers and the rear valence that
> goes under the bumper cover. They are screwed on but Peter mentioned
> that there was also some adhesive holding them on too which I didn't
> know about.
> I just want to make sure since the body guy is fitting everything
> right now.
> > Mike, since you brought it up: My '88 McL has the side molding from
> front fender to rear. This is put on with tape.
> > How do I know? Fortunately, one piece came off and was laying on
> the garage floor.
> > So my two cents: Check to see that the molding is on firmly
> attached. IF IT COMES OFF when you are trying to see if it is firmly
> attached, get some double-sided tape (automotive - AUTOZONE; etc.)
> and reattach on a warm day. And, thoroughly clean the painted under-
> surface with alcohol as well as the to-be-attached surface.
> > I do not know about the rocker panels.
> > Dick
> > From: negusm
> > To: ascmclaren@yahoogroups.com
> > Sent: Thursday, February 12, 2004 9:50 AM
> > Subject: [ASC McLaren ] Coupe Rocker Panel and rear Cover
> installation
> > How did these attach? They look like they just used screws on
> either
> > end and inside the door frame.
> > Was there any adhesive used?
> > For the rear valence, was it rivetted, screwed or glued on?
> > thanks.
> Groups Links
> > a.. To visit your group on the web, go to:
> > http://groups.yahoo.com/group/ascmclaren/
> > b.. > >
> > c.. >
Groups Links
4484 Re: Coupe Rocker Panel and rear Cover installation negusm negusm Thu  2/12/2004
