4524    <<    Message Index    >>    4526
Number: 4525
Date: Wed Feb 18, 2004  7:11 pm
Subject: Re: 85 asc vert
Re: 85 asc vert
Sandy,
Good point that the dash kit may be/likely is a replacement...I
wouldn't make the jump that the car has therefore been at the bottom
of a lake though. Maybe I am nieve, but this car doesn't appear to
me as though it has been immersed in water - at least for any amount
of time. Perhaps you have some info that I don't.
Like I said in my previous post, I have similar bumps showing through
my toneau cover, but no evidence of rust, etc. Why they are there, I
don't know. But I know my car hasn't been immersed in water.
Regarding the kickplates, the scratches seem to show that a lighter
beige is showing through the crud (again I have no idea where the
crud could have come from) and there appears to be some blue
overspray over the beige color on the right one.
I disagree w/ your statement regarding the signature plate. Perhaps
some cars had the black backing w/ orange stripe, but mine was
definitely exactly as shown in this picture and the picture of the
other "Sean's 85" in the "Files" section, which clearly shows no
backing/orange.
Sean
> The dash kit in that car is a replacement! It lacks the thin
> diagonial lines of darker brown running thru it.
> There are no bolts/screws connecting the tonneau vinyl "hump" to
> tonneau cover.
> The kick panel is not beige, it's blue, but water damaged. The
> plastic plugs holding it in there are obviously new.
> Every 1986 1985 'Vert I have seen has the plaque set in a black
> plastic base, with raised plastic edge encircling the gold plaque
> with a vermillion (red-orange) painted "frame"...
> -- In ascmclaren@yahoogroups.com, "cassman108" <cassman108@y...>
> > I haven't the slightest idea whether this car has been immersed
in
> > water as Sandy speculates, but a couple of things I noted when
> > looking at this car, comparing it to my car of course.
> > 1. My car has some bubbles under the tonneau similar to this car
> and
> > I know that it has not be immersed in water. Perhaps there are
are
> > screws or rivets under the tonneau cover that become evident once
> > vinyl settles or perhaps there is some way that rust could occur
> > under the cover. I have never taken my cover off, so I don't
know
> > for sure. I don't have rust on the underside of the tonneau
itself
> > either.
> > 2. The Recaro's look a hell of a lot better than mine,
considering
> > that this car is a Nevada desert car and it has a fairly dark
> > interior. Mine was used as a "beach" car in New England and
> suffered
> > quite a bit of sun damage and its beige.
> > 3. As far as I can tell, the signature plaque is exactly as it
> > should be on this car. It's a bit oxidized like mine was before
it
> > fell off/was stolen. My car and the verts I have seen pics of
did
> > not have the black backing w/ orange stripe around it. Note the
> > picture of the other Sean's 85 vert in the "Files" section. If
you
> > zoom in on the plaque, you will notice it doesn't have the black
> > backing piece.
> > 4. The kick panel is a mystery to me though. It looks like its
a
> > moldy beige one like Sandy says. Who the hell knows what that
kick
> > panel is doing in this car.
> > I could be wrong, but this car doesn't look like its been under
> water
> > to me. When seeing Sandy's comments, the first thing I looked at
> was
> > the wood dash kit. Seems to me that the dash kit in this car
would
> > be warping/peeling off w/ the slightest hint of water. Mine was
> > wrecked by the sun only.
> > My unsolicited 2 cents. I would post some more pics of my car to
> > show you what I'm talking about, but the photos section is still
> down.
> > Sean
> > 85 vert 58
<cigarsandy@c...>
> > > It's my belief that this very good looking '85 Capri went
> > swimming!
> > > That's correct, as in flood waters!
> > > Look closely and see if you can see what I see.
> > > 1. Perfect body, no rust (been fixed ??) *BUT* under the
tonneau
> > is
> > > rust. See the rust bubbles poking thru the vinyl cover on the
> > > tonneau? It can ounly rust from the underside up, as the
tonneau
> > > covering will dispell any water on it. It's covered. They
could
> > not
> > > get under it to dry it & could not see the wet, as it is/was
> > covered
> > > by the vinyl
> > > 2. I'm sorry, but Recaros in these do NOT look that brandy new
> > after
> > > 67,000 miles, likewise the carpeting, but of which are new,
new,
> > new!
> > > But....check out that moldy, discolored passenger's side kick
> > panel!
> > > Straight from the "lake" !
> > > 3. The side signature plaque....why is it missing its original
> > black
> > > plastic frame in which it sits? You know, the one with the
> orange
> > > painted boarder. If the entire thing was lost, okay...it's
> lost.
> > > But to me this one appears to have become seperated from its
> base.
> > As
> > > can be seen here, on mine:-
http://images2.fotki.com/v10/photos/4/43979/169659/Sanfordsrollingstoc
> > > > http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?
> > > > ViewItem&category=5366&item=2461311245
font>
