4611    <<    Message Index    >>    4613
Number: 4612
Date: Mon Mar 1, 2004  3:34 pm
Subject: Re: [ASC McLaren ] NOW - - I NEED HELP !!!
Sandy,
Whoever you take it to have it serviced, whether it's your dealership or
someone else, have them put a soft cloth or towel on top of the steering
column BEFORE they pull the cluster out to get to the back of the
speedometer to disconnect the cable.
I had my instrument cluster out last spring to clean & polish up the lexan
and replace a couple of light bulbs and found out after it was too late that
the bottom edge of the cluster is pretty sharp and it will scratch up the
top of the steering column pretty badly without something there as a barrier
to protect it.
Brent----- Original Message -----
Sent: Monday, March 01, 2004 3:06 PM
Subject: [ASC McLaren ] NOW - - I NEED HELP !!!> After helping so many - now I need some H*E*L*P !!!!!
> Yesterday, Leap Year Day, I finally removed my 1985 ascMcLaren
> Mercury Capri COUPE. I brought it home overnight & took it today,
> 3/1/'04, to the Ford Dealer that it has gone to since new, (they know
> the car & respect it) for normal servicing. My problem is all the
> way over (8 miles) I hear a whurling sound. Sticking head out window
> I quickly realized that it is NOT coming from the wheels. When I go
> fast, the whurling is fast, when I slow down it slows down too (the
> wurling sound). When stopped for a traffic light it is not present.
> I can to my own conclusion that it's the Speedo cable. I checked at
> their parts dept. and it is available and the same was used from 1986
> thru 1995. It's like $89.00 or so.
> Now my question is this: The Tech says it's like 2 hours labor
> ($165.00) and much of the dash has to come apart, to install it. IS
> THIS TRUE? Is there another way? Seems to me that years ago these
> things could be changed from UNDER the dash without removal of the
> dash. Tech also said when warm (~HOT~) weather comes, andwith some
> on the road usage, she'll probably cure herself. Is this true?
> Possible ?
> Thanks in advance. (Mileage is 639 ~ getting up there!!)
Groups Links
