4620    <<    Message Index    >>    4622
Number: 4621
Date: Tue Mar 2, 2004  11:29 am
Subject: Re: [ASC McLaren ] NOW - - I NEED HELP !!!
Well, sad to tell you guys that I am about as "mechanical"
and/or "skilled" as your grandmother! I can change a taillamps bulb
and that's about it! I do NO work on my own cars and pay dearly to
have what needs top be done >>> DONE ! Therefore, I am at the hands
of my dealer, who charges $86.25 @ hr. labor rate, just like the
washing machine/dryer repairman does. I think I'll wait until late
July, and see if the weather (HOT) changes anything, and drive it a
bit. If no improvement, I'll have the thing lubed & done in August,
requesting to have the steering column sleeve removed, maybe should
also remove the leather wrapped steering wheel too, just to be
safe ??? The car also had severe "flat" spots on the 4 tires and
felt like they were square tires. However, in the 16 mile trip, that
went away. They are the original, no longer available B.F. Goodrich
Comp T/A P225x50/15" rubber.
-- In ascmclaren@yahoogroups.com, "negusm" <negusm@y...> wrote:
> I have to agree with all of what Marq says.
> The speedo cable does have a plastic clip on it that you have to
> pinch to disconnect it. I cannot remember if you had to pinch on
> both sides though.
> I do not remember the cable "separating" like Marq says, but I
> wasn't looking to separate it, just get the gauge cluster out.
> If the cable does separate, I would do what Marq says and clean it
> up and relube it. That whole job shouldn't take too long.
> > Hi Sandy....
> > My first thoughts on your tale of the mysterious 'whirrrr' sound
> are this : That model of car would have a mechanical speedometer -
> meaning that there is a flexible cable running from the
transmission
> up to the back of the speedometer. Basically the speedo cable
> looks like a bicycle cable with a plastic coated wire outer casing
> and a 'multi-wire' center core. The problem with the multi-wire
> center core is that it has the potential to 'rust'.
> > So if you can imagine this multi-wire core spiining around within
> the plastic coated and metal reinforced jacket, there is the
> potential for a bit of noise when a car has been sitting for quite
> some time.
> > Normally the inner tube of the cable is saturated in lithium
> grease and the constant spinning of the inner wire keeps the
> lubricant well distributed - hence little or no noise.
> > If the cable is making the noise, it would travel the length of
> the speedometer cable and you would hear it at the the speedometer
> and down at the ratio gear at the transmission.
> > Being a 'cheap SOB' I would do one thing to test the theory
out.
> Normally you can gain access under the dash to be able to get a
hand
> up an on to the back to the dashboard. I know for certain this is
> possible with the Firebirds, and I seem to recall having done this
> with my Mustang as well. Normally the part of the speedo cable
> that clips into the speedometer is held in position by a clip that
> pinches it from both sides. If you depress the clip you 'should'
be
> able to disconnect the speedo cable from the speedometer.
> > Ok... having accomplished that.... you should 'normally' be able
> to pull the inner core wire out of the cable that it is encased
> in. Once out you can inspect it to see if it has the brown
> evidence of rust. If everything looks shiny and black ( from the
> lithium grease) than it may be that this was not where the problem
> was. You can than recoat the inner cable with fresh grease and
> stuff it back into the speedocable. The trick here is to make
sure
> that when you insert it that it goes all the way back down to the
> ratio fear and fits back into it snuggly. The ratio gear end of
> the cable has been formed to have a 'square' shape and by gently
> twisting the cable as you reach the gear ratio you can ensure that
> you have insert the square end snuggly into the square receptable
at
> the rear ratio. You than simply snap the speedometer end of the
> speedo cable back into the back of the speedometer.
> > NOW... if the cable turns out to have been rusty... than you can
> steel wool the length of the cable to clearn all the rust shards
off
> the inner cable, re-grease it up, shoot some lithium grease down
> cable to grease it up, and than go through the re-insertion steps I
> mentioned above.
> > One thing about speedometers themselves, is that they are know to
> go flakey at some point with normal wear and tear. In the case of
a
> vehicle that does not have much mileage on it, one would have to
> assume that 'atrophy' may simply set in at some point - and affect
> the speedometer mechanicanism in a way somewhat similar to normal
> wear and tear.
> > With regards to the possibility of just ignoring the sound and it
> may disappear... I believe that is the course of action that most
> people would take. If it was a lack of lubricant on the inner
> speedo cable... than putting some milelage and use through the
cable
> would hopefully re-distribute the grease that is probably sitting
in
> the cable - bringing about silence.
> > Similarly, if the speedometer itself has gone slightly wonka from
> lack of use, than possibly putting some miles on it would also have
> a similar positive effective on ending the 'whirring' sound.
> > If the 'speedometer's time has simply come to act 'wonka' than
> there is not much that can be done about that. Usually the
initial
> signs of the speedometer going 'wonka' is that the needle of the
> speedometer jumps a bit eratically when driving along at a steady
> speed. Normally you don't get to the noisy 'speedometer' stage
> until the car has done a bit of erratic behavior in its reporting
of
> your rate of speed.
> > Nuff said.. .hope this helps give you some additional thoughts.
> > Marq
4623 Re: NOW - - I NEED HELP !!! negusm negusm Tue  3/2/2004
