4668    <<    Message Index    >>    4670
Number: 4669
Date: Wed Mar 10, 2004  2:08 pm
Subject: [ASC McLaren ] Re: Interesting figures
618892 is a EuroCoupe, Oxford White. Received AT ascMcLaren on July
15th 1986 & shipped out on July 24th 1986. It's the 13th of the 47
EuroCoupes. They made 34 after it. It's one of 14 in color.
Regarding the Buck-Tag:-
618892 is of course your sequence VIN. 61D is the code for a Capri 3-
Door Hatchback. The "M" is the code for the 302 Cu In V-8 with EFI.
9L is the code for Oxford White, while the PW is Power Windows.
The HB is the build date of August 2nd H=Aug B=2 They built 1,977
1986 Capris AFTER yours.
Mustang took 93% of the build and Capri took 7% of the Dearborn 1986
model year build, which was 245,279, or 20,869 Capri & 224,410
Mustang.
> I don't have my door tag info handy but my body buck tag reads as
follows:
> CAPRI
> 618892 61D M 0127
> 9L DF ST
> AC 06 HB
> PW 02
> A EI 06 2 X 2 NLR
> And of course the other smaller tag next to it that reads:
> MCLAREN COUPE
> MCLAREN COUPE
> MCLAREN COUPE
> Brent
> 1986 EuroCoupe, White, Automatic
> Sent: Wednesday, March 10, 2004 10:59 AM
> > Yes, it would be nice if we could get some owners to post more of
> > their buck tags, door tags and any legible build sheets.
> > My door tag as everyone probably has seen before is:
> > http://www.ascmclarencoupe.com/History/MasiBefore/door_tag.jpg
> > My buck tag is here but I don't have the info on it:
> > http://www.ascmclarencoupe.com/ascParts/asc_BodyBuckTag.jpg
> > Its in front of the radiator attached to the cross bar.
> > > Again, the door tag DSO is different than the internal DSO
code.
> > > The door tag DSO is for the District Sales office. This 2
digit
> > > code merely shows what district the car is/was intended for.
For
> > > cars that were special orders there is an additional 4 digits
that
> > > are undecipherible without internal paperwork.
> > > D32 is a code Ford used internally at the plant to identify a
> > > McLaren build.
> > > IF everybody would offer up their door tag info we could try to
> > > narrow down what codes are common for these cars and use those
> > also
> > > as identifiers. For instance, maybe all McLaren Capri coupes
had
> > > the same DSO or maybe they all used the same spring codes which
is
> > > coded with the transmission on the tag or maybe they all have
> > > same Accesory Reserve Load codes that is printed above the DSO
on
> > > the door tag. This could be done for the Coupes, Capri verts
> > > the Mustangs also. There is nothing except the VIN on this tag
> > > identify the car so a picture or two of the tag, with only the
> > last
> > > 6 digits of the vin blocked out if you so choose, would be
great.
> > > If Sandy wants to handle the load of pics or if Negusm wants to
> > > fine, or I can too. A few examples of the tags:
> > > http://www.sspmustang.org/technical/doortags.htm
> > > Tom S.
--- In ascmclaren@yahoogroups.com, Peter Shear <tfs2121@y...>
> > > > what about the door tag would it say anything about
> > > > the D32 build code or something?
> > > > ~Peter
> > > > __________________________________
> > > > > > > Search - Find what you're looking for faster
> > > > http://search.yahoo.com
> Groups Links
4670 Re: Interesting figures Sandy Block cigarsandy Wed  3/10/2004
