Yes, I have a SUPER sized photo of it and a good bit is legible. I need my dad to get a rubbing of it.
I'll post it tonight.
--- In ascmclaren@yahoogroups.com, "Sandy Block" <cigarsandy@c...> wrote: > MIKE, any chance you could get a better shot of your build tag? I > really cannot read it. A better pic & I could tell you most of it. > > S A N D Y > > > > > >
--- In ascmclaren@yahoogroups.com, "Tom S." <tkm654@c...> wrote: > > > Again, the door tag DSO is different than the internal DSO code. > > > The door tag DSO is for the District Sales office. This 2 digit > > > code merely shows what district the car is/was intended for. For > > > cars that were special orders there is an additional 4 digits > that > > > are undecipherible without internal paperwork. > > > > > > D32 is a code Ford used internally at the plant to identify a > > > McLaren build. > > > > > > IF everybody would offer up their door tag info we could try to > > > narrow down what codes are common for these cars and use those > > also > > > as identifiers. For instance, maybe all McLaren Capri coupes had > > > the same DSO or maybe they all used the same spring codes which > is > > > coded with the transmission on the tag or maybe they all have the > > > same Accesory Reserve Load codes that is printed above the DSO on > > > the door tag. This could be done for the Coupes, Capri verts and > > > the Mustangs also. There is nothing except the VIN on this tag > to > > > identify the car so a picture or two of the tag, with only the > > last > > > 6 digits of the vin blocked out if you so choose, would be > great. > > > If Sandy wants to handle the load of pics or if Negusm wants to > > > fine, or I can too. A few examples of the tags: > > > http://www.sspmustang.org/technical/doortags.htm > > > > > > Tom S. > > > > > > > > > > > >
--- In ascmclaren@yahoogroups.com, Peter Shear <tfs2121@y...> > > wrote: > > > > what about the door tag would it say anything about > > > > the D32 build code or something? > > > > > > > > ~Peter > > > > > > > > __________________________________ > > > > > > > Search - Find what you're looking for faster > > > > http://search.yahoo.com
