Use 08/85 as the date long with your vin and either copy the rest rom my tag or see what you can from yours to fill in the DSO and spring codes under the "TR" section (mine is 2BBBB, 2 = 5 Speed, BBBB are the front and rear spring codes). Everything else will be the same.
The DSO code is somewhat important to ID an 85Coupe as an asc. Part of it (i forgot) will tell you where the care was destined to. If you know where your car was purchased you could guess at that part.
The spring codes aren't much use at all as asc switched things around later anyways.
If the DMV ever looks at it they will just look at the VIN and match it to the one under your windhsield.
--- In ascmclaren@yahoogroups.com, Peter Shear <tfs2121@y...> wrote: > what do you do when you cant read your door tag!!! oh > no!!! its all faded and id like to get a new one from > that guy but he says i have to have all the #s can > someone help me make a new one for my blue 85 mclaren > coupe it has everything but PL and from what i > understand it was built in augest > > ~Peter > > __________________________________ > Search - Find what you're looking for faster > http://search.yahoo.com
