4888
4890 Number: 4889 From: "Sandy Block" Date: Sat Apr 10, 2004 12:24 am Subject: Re: 86 McLaren Capri
it's correct. Actually I have seen 1985 'Verts with BOTH! "ascMcLaren" on some & "5.0SC" on others, and this NEW ON LOT.
--- In ascmclaren@yahoogroups.com, "ecstacycustomz" <ecstacycustomz@y...> wrote: > my front grill emblem is the 5.0 sc is this only used on the 85 > vert? it is the original emblem off the lot. > jdawg > > > >
--- In ascmclaren@yahoogroups.com, "Sandy Block" <cigarsandy@c...> > wrote: > > The 1986 Mercury Capri ascMcLaren 5.0SC 2-Seat Roadster did NOT > come > > with any decals ! In the grille (driver's side - off center lower > > bar) was a chromed plastic nameplate that said:- ascMcLaren. It > had > > a sticky-back and simply pressed onto the existing "mercury" > > nameplate. At the rear on the deck-lid turndown, just above the > > taillamp on the passenger's side another plastic chrome plated > emblem > > that said: 5.0SC > > That was the extent of identfication on your car. The decals were > on > > the COUPE. On the passenger side (only) between the door opening > & > > the rear wheel well cut-out was the LIMITED EDITION plate. All > of > > these can be purchased at: > > ascmclaren.com - - UNDER "PARTS" section on Emblems. > > > > S A N D Y > > > > > > > > > > > > > > -- In ascmclaren@yahoogroups.com, Steven Stuart > > <armyman19781998@y...> wrote: > > > I own a 86 Capri Vert and I am looking for two things: > > > 1. Schematic of eletrical system, mine is really messed up > > > 2. ASC Mclaren decals for the car > > > > > > Thanks > > > Steve in Spokane > > > > > > > > > --------------------------------- > > > > > Small Business $15K Web Design Giveaway - Enter today
