Where are the nine now?
Argo
Post by Argo »
If I could figure out how to get the PDF on here I would post it for all to see.
So I will transcribe part of it.
Original email from Sandy
Sent April 12, 2002
BINGO ! YOU DO !
Ian,of the 245 made for 1986(YES, yours is a 1986, the final year for the Mercury Capri version) a mere 9 (NINE) were factory equipped with a3.8Litre V-6 engine!! YOU HAVE ONE! (and) it's FACTORY ORIGINAL!!
Your car was #14,186 1986 Mercury Capri built and the 185th to be customised by ASC into what you have. It's a very rare car!
I have located just 2 others, both in the USA, for a total of 3 of the 9. Yours is the only 3.8Litre V-6 outside the usa.
ASC introduced the asc/McLaren 3.8 SC 2-Seat Roadster. This is what you have.
SANDY
KHummel66
Post by KHummel66 »
Ian,
I'm guessing here, so correct me if I guessed wrong -
Are you looking at the last line of 4-barrel Mike's post containing pics of your car, where it says "1985 5.0 SC, white/blue, modded by POs (more mods coming)"? If so, that is his signature line describing his car, not something he wrote as a description of your car. You both happen to have white/blue cars; his an '85 V8 and your's an '86 V6.
Keith
1986 ASC vert - #86-0001
1986 ASC vert - 3.8SC v6
1985 ASC vert - Black/Tan/Tan
1985 ASC coupe - modified
1985 ASC coupe - roller
1983 Crimson Cat V6
1966 Cobra replica
Argo
Post by Argo »
Hi, yes, I didn't realize that at the time, I got it when I looked at his replys to other posts, ;o). It wasn't obvious at first. Thanks. Ian.
4-barrel Mike
Post by 4-barrel Mike »
Oh! :banghead: THAT's what you were asking about!
Sorry, Ian, I'm an idiot. :D
Mike
Argo
Post by Argo »
Hi Mike, not a problem, it was great to see the pics there, Ihad tried to do it myself earlier with no luck so posted them in album, Good job ,Thanks. Regards Ian.
Argo
Post by Argo »
Is it possible to get a list of the nine serial numbers? (where they built one after the other or randomly in 1986). How many are actually left?
Argo
Post by Argo »
Hi. Can anyone tell me the part number of the heater matrix as I need to replace mine.
Re: Where are the nine now?
Argo wrote:Hi. Can anyone tell me the part number of the heater matrix as I need to replace mine.
Please explain your request so the silly Americans here can understand it and get you a proper reply.
Heater core
Heater hose
Heater control panel
And of course we would need to know if the car has factory AC.
Argo
Post by Argo »
Hi. I need a heater matrix for my 1986 3.8 V6 McLaren and all places I have tried want part numbers. I have received a link from 4-barrel Mike for this part and many others. It's like being in a sweet shop. Thanks Mike😊.
Parts
I still don't understand which part you are talking about when using the word "matrix". I listed the common heater replacement parts in the previous post.
Argo
Post by Argo »
Hi. Yes it is the heater core .we know it as heater matrix. Like hood and bonnet. trunk and boot and fender and wing etc.😊. Ian.
Part
Ah, that makes sense now. I tried a translation but that did not work.
AC cars use a different one than non-AC cars. The heater core is a tough 6-8 hour job on an AC car. You want to use the best part available so you don't have to do it again. The Motorcraft (Ford) copper/brass heater core was the best part, Motorcraft HC5 Heater Core. Unfortunately, they no longer make them. The current Motorcraft heater cores are aluminum. There is no verdict on these new ones yet. I do see they advertise a 10 year warranty now.
Ford parts also sold a replacement heater core E9LY18476A and is obsolete I believe.
The old Motorcraft parts which lasted a long time had a the angled tube soldered to the end plate. Take a look at the picture and you will see the angled tube.
For non-ac cars, replacing the heater core is a 15 minute job so any brand can be used.
4-barrel Mike
Kevin, a question of ignorance: did they make any non-AC McLarens?
Mike
4-barrel Mike wrote:Kevin, a question of ignorance: did they make any non-AC McLarens?
Mike
I don't think so.
ac
Mike
I don't think so.
I would suspect the same. If any were without AC, I would speculate it was the budget 6 cylinder models. It does make a difference to get the right part.
