'86 White/blue roadster in FL on eBay
Buy, sell or post an ad you've seen about ascMcLaren cars or parts.
capri50asc
If you need help let me know
Post by capri50asc »
If anyone has questions on the 86 ASC Capris or hardtops let me know
Chris
1986 ASC Capri Vert #0082
1986 Capri RS 5.0 5 Speed
2014 Honda Ridgeline RTL
1973 Mercury Cougar :)
Anonymous
Post by Anonymous »
Hi Chris,
I am sure I will have some before long. However to get off on the right foot with my Florida 1986 ?? The seller mentioned he would put excess parts in vehicle for shipment including the ground effects for side and rear. I believe they are a custom add on. Thanks and look forward to your input. Dean
capri50asc
Optional ground effects
The Optional ASC/McLaren equipment was the following as I read it off the order form I have:
Recaro Seats : Heated , leather surface, adjustable leg supports and dual speakers with adjustable lumber (air operated pumps) with three bags per seat.
Whistler Radar Detector with remote mount behind the passengers high beam
Performance decor package included Ground effect skirts headlamp and tailight covers. ( Hank sells the head light covers that are repops and darker in color)
ASC Floor mats
140 Mph speedometer (Ford Motorsport) This does NOT have a overlay on the surface
As for the ground effects there is (4) pcs A front air dam style that has Hella fog lights with a mounting bracket. You will need to cut the front bumper just below the belt line and insert it behind the top facia. The side extenders mount to the rocker panels The rear part fits under the rear bumpier, Make sure you have at least 1/2 around the tail pipes to keep heat from damaging the part
Thanks Chris :D
Anonymous
Post by Anonymous »
Hi Chris Ok that is a help. Much appreciated think I have the front end for the ground effects not sure but the fog lights are in the center of the front unlike some of the others I see in the pics. Thanks again Dean
Anonymous
Post by Anonymous »
I am now sure the information in the heading was correct it is indeed a 1986 with the wood trim dash based on pictures does the number correspond with the vehicle as in #49 of 350 and where would I find that type of information. Thanks to all for your support with this new journey. Dean
4-barrel Mike
Post by 4-barrel Mike »
Welcome, Dean! :celebrate:
Mike
1985 5.0 SC, white/blue, modded by POs (more mods coming)
Anonymous
Post by Anonymous »
Thanks Mike certainly a benefit to have a site like this while I am new ,I will ask you the experienced what is the best repair manual to have for these vehicles. Thanks again Dean
capri50asc
Front Air Dam/Spolier
Dean
The Front Air Dam you have on your car is the one I have on my '86 Capri RS That Air dam was not used on the ASC Coupe or verts.
It was used on the following cars:
1979 Ford Mustangs Pace Cars and Cobras 80-81 Part number starts with
D9 This air dam was cut different to fit into the belt line (moldings) and the 1982 Ford Mustang GT with the early 4,2 engines (rare) and the return of the 5.0 liter
In 1984 Mercury used it in the Capri RS and (84) Turbo models and the part number changed to E4 It was then used on the 1985-86 RS/5,0L Capris with the 5,0 engines.
The side extenders are all the same and are being repoed by Johns Cougars in Holland Michigan
Dean there is 6 pcs to the air dam you have and it was cut into the top part of the bumper OR someone used the top fascia from a 85-86 Capri RS and just added it on the car Hank at ASC McLaren.Com has the correct one if you need one or go to Ebay Go to Search. Type in asc mclaren and you will find it in the listings. Hank will also have the Hella Fog Lights on his web site if you need those and a light bar for the correct look on your car. Then remove that Air Dam with the light bar and the two marcel lights and sell it as a package and it will bring $300-$400
NOTE the Light bar is the same from 1979-86
Thanks Chris
Anonymous
Post by Anonymous »
ok thanks again Chris now I got it. Dean
Kentennis
Post by Kentennis »
86MclarenCapri wrote:OK, sounds like you don't need that AC working, right?!
I went through uShip to get mine delivered from California to VA, It was like $950.
You're on the ball!
I had a 65 Thunderbird delivered from Arkansas to Florida for $600.00.
Anonymous
Post by Anonymous »
That sounds reasonable hope I get an offer in that neighborhood lol probably double. Have some more information on the vehicle it is a Florida vehicle and I await the actual carfax and title. So things are moving all be it slowly. Have a great night all Dean
Anonymous
Post by Anonymous »
I receive the VIN # and here it is looks like you were all right a mistaken number on listing took it to the 1984
1MEBP79M6GF604001
Thanks all
4-barrel Mike
Back on eBay with the VIN immediately above (1MEBP79M6GF604001). Still in Florida. No reserve starting at $.99, buy it now $1,750.
http://www.ebay.com/itm/1986-Other-Make ... 1995479495
Mike
86MclarenCapri
What happened??
Post by 86MclarenCapri »
Dan
Norfolk, VA
67 Mustang GTA Convt
