Tonneau Applique removal
Post your build projects here. Restorations. Repairs. Anything that is project related!
1987JonnyVinyl
Post by 1987JonnyVinyl »
Is this panel glued or double stick taped on? Any tricks to removing?
I don't own a vert but pretty sure it is glued on.
birdiestobehad
Post by birdiestobehad »
My 1986 convertible had it glued on. I had the same issue about 9 years ago.
Here is the link to the forum post from back then:
http://www.ascmclaren.org/phpBB/viewtop ... neau+cover
Hope this helps.
Terry M.
1986 'vert #118
1987JonnyVinyl
Sounds lke most we damaged. Did you do anything special to avoid damaging the panel?
birdiestobehad
I don't remember anything specific or special. I know at least one side was detached for a couple of feet in and I just lifted it enough to get my hand underneath and flat to the deck. I slowly kept pushing with my hand flat on the deck (like a wedge), working it back and forth and it came up fairly easy. Which meant it could have flown off while driving with the top down!
Good luck!
Terry M.
1986 'vert #118
