An ascMcLaren forum for 84-86 Capri and 87-90 Mustang based cars modified by Automotive Speciality Corporation, a Division of American Sunroof Corporation. (no affiliation)
Either this car was a 5-speed from the start and swapped to aod or the air cleaner lid was swapped and is efi car or truley does have a carb and not efi but in any case not original but still a decent looking ASC vert.
-DAVID-
MY KEEPERS!
2003 SILVER MERCURY MARAUDER 320 HP 32V DOHC.
2013 FORD F150 RAPTOR "TERRAIN TAN" 4X4 CREW CAB & LIFT ON 37s.
2016 SHELBY MUSTANG GT-H HERTZ EDITION #82 OF 171.
1995 F-350 CREW CAB DUALLY POWERSTROKE FULL BANKS KIT!
Correctly does NOT have the ascMcLaren emblem on deck lid, but does have 5.0SC on right side of deck lid. Correct 5.0SC in grille. Correct door panels, seats, steerring wheel. Incorrect rims. Correct roof. Looks like a B grade, maybe a B- what with the Carb question......Seen better, but seen alot worse !
It's just the air cleaner lid that has been swapped. You can still see the solenoids on the drivers fender for the CFI system. Looks all to be hooked up. If it were converted to a carb a mess would be seen of the wiring.
