85 asc coupe #607922
The listing of what HAD BEEN proposed ? I don't want to make all the Coupe owners ill. The bigger question is:
Which manilla envelope is it in ? There are 17 overstuffed manilla folders, and 3 super overstuffed photo albums, from everything from right hand drive examples "down under" to an ascMcLaren Notchback Coupe, with a vinyl roof. It's really all endless. Dealer stuff, too, order blanks and inter office correspondence. (asc to all dealers,,,,)
i wont get ill sandy... tell me a story befor bed time please
The build info really is mostly listed all here:
http://www.ascmclaren.org/phpBB/viewforum.php?f=6
It's pretty detailed.
The list of proposed items, I am not sure of...I know sandy mentioned a short list one time. Not sure where that is.
Here it is:-
Product Content Summary
September 22nd 1982
ASC McLAREN Capri Coupe
(Sandy Will ONLY list the items that went to the cutting room floor)
New Cast Aluminum Valve Cover. Finned Design witjh ascMcLaren Logo cast into the top surface.
Upgrade Exhause Header (Stainless Steel) Internal Mandrel Bent.
Exhaust Port LIners, to be tuned with lower restriction exhuast.
Tuned Muffler to reduce back pressure & enhance exhaust "note" ever further.
Engine Compartment "Dress-Up" To make the compartment highly visually appealing & more High Tech Looking.
Replace Damper Units & springs to achieve better cornering & a softer ride than TRX System.
Modify camber of vehicle front & rear to max out performance of up-graded tire/wheel combination. Requires Wheel Alignment.
Increase Suspension Bushing Durometer.
Revise Braking System by changing lining materials & adding a proportioning Valve.
Revise Pwr. Steering to give more feed back.
Change shift linkage to shorten throw. (Hurst?)
Replave valve springs & rocker arms to increase usable rev. limit to 7,000RPM
Unique instrument gauges incorporating VDO gauges or any other Hi Tech look.
Replace stock console with more Hi Teck unit, leather covered, to accept add'l. gauges.
and....
Custom Rear Deck. Hand layed-Up fiberglas constrction using either the steel inner panel from stocxk deck lid or building on a new inner panel. to be primed &painted body color & feature new style glass rear window to be glued in place and trimmed with vacuum formed cover.
REMEMBER;
these are only the things that I think the cars do NOT have. Everything WE DO have is also on the listing....
Now, you all have it !
P R I N T I T
