85 Special Equipment Parts List
I'm trying to sort out the 85 Special Equipment Parts List for my car. This is what I have so far.
1. Bag- no Ford part number so I'm thinking it was a plastic bag to put all the papers in.
2. Grill- That's easy and looks to be a standard 85 grill probably from a different trim model. It also explains why there is no Capri name on the grill.
3. Wiring e5zb14334aa- probably the harness for the lighted rear view mirror since it is listed next. Looks to be standard mustang (convertible?) part.
4.Mirror e4zx17700aa- mirror part is easy, but there is something special about this 84 part.
5. Housing e2zb14a335ab- not sure what this is but possibly a left and right side part with the next one. Standard part from 82 mustang.
6. Housing e2zb14a443ab- not sure what this is but possibly a left and right side part with the previous one. Standard part from 82 mustang.
7. Housing e2zb14a660ab- not sure what this one is but there 2 of them. Standard part from 82 mustang.
8. Manual- Number matches my Incomplete vehicle manual.
9. Molding e3zb6120544ab2pb- possibly the rear quarter molding from the LX (non GT)? No, that would have an e5zz number. This is a standard part carried over from the 83 mustang.
10. Molding e3zb6120545ab2pb- possibly the rear quarter molding from the LX (non GT)? Same as above but the other side?
11. Cylinder e4zb6121984ba- possibly the black ignition lock.
12. Handle e3zb6122400b5aa- possibly the black inside door handle.
13. Handle e3zb6122401b5aa- possibly the black inside door handle.
14. Regulator asy e5zb6623200aa- easy one door regulator, probably from the 85 mustang convertible.
15. Regulator asy e5zb6623201aa- easy one door regulator, probably from the 85 mustang convertible.
16. Panel e4zx61044b78-bd- this one is the dash panel on the passenger side which is similar to the SVO mustang and is likely the same part. Most svo specific parts are e4zx (84, mustang division, experimental).
17. Panel e4zx61044b70-bc- this one is the dash panel on the driver side which is similar to the SVO mustang and is likely the same part.
18. Trim e3zx7600023aocync- no idea on this one.
Ford parts Not listed:
-SVO steering wheel e4zz3600a
-Center horn pad e???3649?
-Springs (bumper height is adjustment listed possibly for lowering)
-Tie rod ends
-radio antenna delete
-Trunk lid
-manual lists Capri GS model with exterior/interior moulding delete package (incomplete vehicle) trim mouldings and headliner deleted
Any insight would be appreciated.
