Window Channel on a 86 Eurocoupe
Where can I get (I call it window channel) the black rubber/felt that the window rolles up into & how hard is it to install?
Zeke 86 Eurocoupe
www.50resto.com
It is fairly easy once the door panel is off.
Lube the outside up a bit (vaseline or whatever) before you get it seated in the front channel that goes wayyyyy down in the door.
Thanks Mikenegusm wrote:www.50resto.com
Zeke 86 Eurocoupe
- mustang marty
You may want to wear gloves when you get them. I am not sure if the 50Resto ones are the same as the ones from FMR (foxmustangrestoration.com), but when I pulled out one that I ordered from FMR, every place that my skin came in contact with it itched for a couple of days. I forgot about it a few weeks later and took them out of the box again and started itching. It seemed to be some kind of a chemical irritation
I don't know of anything that I am allergic to, but it could just be me.
I will find out. Ordered them from 50Resto.mustang marty wrote:You may want to wear gloves when you get them. I am not sure if the 50Resto ones are the same as the ones from FMR (foxmustangrestoration.com), but when I pulled out one that I ordered from FMR, every place that my skin came in contact with it itched for a couple of days. I forgot about it a few weeks later and took them out of the box again and started itching. It seemed to be some kind of a chemical irritation
Zeke 86 Eurocoupe
Got the window channels from 50Resto and installed them and had no itching from then. They worked great.mustang marty wrote:You may want to wear gloves when you get them. I am not sure if the 50Resto ones are the same as the ones from FMR (foxmustangrestoration.com), but when I pulled out one that I ordered from FMR, every place that my skin came in contact with it itched for a couple of days. I forgot about it a few weeks later and took them out of the box again and started itching. It seemed to be some kind of a chemical irritation
Zeke 86 Eurocoupe
