0829    <<    Message Index    >>    0831
Number: 0830
Date: Mon Apr 22, 2002  12:20 am
Subject: Re: Hello? A
Sandy, I don't think it's the receiving unit 'cause like you said the
other remote works...Take the remote (that doesn't work) apart and
make sure the button (that you push to disarm/arm the car) is making
contact with the button on the inside. Also, look at the contacts
and make sure no wires are hanging off or have corrosion on them. To
find the receiving unit...try this...get in the car and set the alarm
off...you should hear a clicking sound...trace the clicking sound and
you will find the unit...if you have to, stuff a rag in the siren or
disconnect it temporarily as to not drive yourself and your neighbors
nuts.
Hope that helps,
Mike
> Curtis, like you, I have the 2 remotes. Over the winter, the car
was
> in storage. I went to check it out yesterday, and my remote would
> not open the doors, had to use the key. Later, I returned with my
> OTHER set of keys, and they worked it perfectly. I then tried
again
> the first set and they still didn;t work!! I feel pretty sure that
> it's probably a dead battery, so I went & replaced it with a
correct
> battery, Duracell #21. Put the battery in the correct way, and NO
> GO. It still will not work. So, now I assume that it lost it's
> memory or jumped code. I do not think it's the receiving unit,
> because I'd guess if it were the OTHER remote would also NOT work.
> have no clue how to fix this. I have a very good & honest dealer I
> take it to (actually a Lincoln~Mercury store)-but they are not too
> familiar with these cars.
> My question......Do you know where exactly the receiver is located
in
> these cars? I really don't want them to go on a witch hunt trying
> find it, I'd much rather be able to point it out to them.
> Any help, ideas or suggestions much appreciated.
--- In ascmclaren@y..., txcurtis <no_reply@y...> wrote:
> > Sandy,
> > I have the optional keyless entry on my 90. What can I help you
> with?
> > Curtis
831 Re: Hello? A cigarsandy cigarsandy Mon  4/22/2002   6 KB
