1052    <<    Message Index    >>    1054
Number: 1053
Date: Fri Jul 19, 2002  1:23 pm
Subject: Re: roll bar
Original post is confusing because of the years mentioned. Is this
an ASC MClaren or regular Stang conv? I would presume it is an ASC
Mclaren because of the group you are asking. All the ASC verts
should have a slightly lower roof do to the 20% rake in windshield.
I imagine if they cut the bottom of the roll bar for a custom fit it
may be able to work, otherwise a custom made unit would be required.
IMO I wish someone would make a "style bar" simply for looks
cushioned with a built in third brake light like newer Stangs.
-Nick
--- In ascmclaren@y..., n20capri <no_reply@y...> wrote:
> Hello,
> I put one in my 86 coupe. The fit is practically the same, except
> installing on in a vert is much easier. I got mine from S&W in
PA.
> I modified the bar so that I could retain the back seats and also
> hatch area. Their website is http://www.swracecars.com. There
are a
> number of places that sell rollbars for fox mustangs and they all
fit
> well. Maximum Motorsports has a nice setup. Their website is
> www.maximummotorsports.com. Another place that sells and also
> installs rollbars is Wild Rides. They are in New Jersey. Their
> website is www.wildridesracecars.com. Expect to spend $800 to
have
> one installed. I did mine myself and it's a lot of work, and I
spent
> nearly that much. You can see pictures of mine at my website.
Good
> luck and post some pics if/when you do it.
> Good luck again,
> Mike
> http://www.pages.drexel.edu/~st947g38/myfriends/MikeMartinelli.html
--- In ascmclaren@y..., mauro amato <mauro@d...> wrote:
> > Has any body put a roll bar on their 87 thru 93 conv? If so can
you
> post
> > some pics or tell us where we might purchase one that will fit.
> want to
> > have something protecting me when Iam doing high speeds on
> freeway.....even
> > at normal speeds.
