1133
1135
Number: 1134
Date: Fri Aug 9, 2002 9:55 pm
Subject: Re: McLaren console and rear storage compartment configurations
I am not familiar with what you describe. Every car I have seen
seemed to be the same in that general area that you describe.
1987 & EARLY 1988s had one style console with exposed lighter, while
later 1988s, 1989s & 1990s had the other style console with the
lighter INSIDE the ashtray. Mercury Capri versions of 84, 85 & 86
(Convertibles) had custom made center consoles...
--- In ascmclaren@y..., Marquis Grove <infosyssec@y...> wrote:
> Ok Sandy... here is your trivia question for the day... as if you
don't get enough of them ;)
> I have been noticing some differences between McLarens that pertain
to the console and the 'back
> seat' storage box.
> In some case I have seen consoles that appear to be separate from
the rear storage box. In other
> cases I have seen pictures where there is a carpeting that wraps
from the console across the front
> of the rear storage box. Giving the appearance that the center
console is one unit with the rear
> storage box.
> Can you enlighten me on whether both of these variations are
correct or is the first version the
> correct one and the other variation simply a situation where
someone with extra carpeting went and
> did a wrapping from the center console to the storage box.
> For example, in my McLaren ( which I received with NO CENTER
CONSOLE ) the rear storage box
> appears to have never been joined or carpeted to connect up to what
would have been a center
> console. But I imagine that a 'genuine McLaren console' would not
have attached directly or under
> cover of carpeting to the rear storage box.
> So any hints as to what is correct would be most appreciated and
help enlighten me.
> Best wishes
> Marq
> Marq
> --- cigarsandy <no_reply@y...> wrote:
> > Yes, of course - 2 people were calling me in the house & the door
> > bell was ringing with Fed Ex while I did that!
> > Thanks for the heads-up
> > S A N D Y
--- In ascmclaren@y..., ascmclaren1986 <no_reply@y...> wrote:
> > > Sandy, you ment to say 3:27 gears not 3:23 right?
> > > WAYNE
> Do You Yahoo!?
> HotJobs - Search Thousands of New Jobs
> http://www.hotjobs.com
