1319    <<    Message Index    >>    1321
Number: 1320
Date: Mon Sep 23, 2002  5:24 pm
Subject: Re: [ASC McLaren ] 84,85,86 Coupe "Sails"
I have never removed the plexiglass inserts from my car, but I have looked
at them very closely and it appears that they are just held in place with an
adhesive of some sort, most likely 3M double sided trim tape.
The original sail panel trim that was installed from Mercury is still there,
these inserts are just that, inserted in the three recessed area on the sail
panel that has horizontal lines molded into it.
The only pieces in the rear quarter window area that are ASC specific are
going to be the large plexiglass piece the actually covers the window and
the three smaller plexiglass pieces that are "glued" to the O.E. sail panel.
I'm sure that these would be the only pieces that Hank would have, not the
actual O.E. sail panel.
Brent----- Original Message -----
Sent: Monday, September 23, 2002 5:01 PM
Subject: [ASC McLaren ] 84,85,86 Coupe "Sails"> On my coupe, my passenger side window "sail" (the styled 3 section
> black plastic peice behind the rear window) is busted. I have in
> place, a replacement taken out of another old coupe which is not
> quite correct. It has the "grooves" in it. The ASC one had these
> plexiglass inserts in those sections to give it a nice "smooth" look.
> Question is, I can take the plexiglass inserts out of the old sail
> and "glue" them over the grooves of the new sail....but is that
> correct? How was this done from ASC? Or do I need to just call up
> Hank and buy the whole part?
1324 Re: 84,85,86 Coupe "Sails" negusm negusm Mon  9/23/2002   3 KB
