im sure all the mustang ascs that i have seen were lower than mustangs, however i own the capri asc so i cant say 100% bout the stang version, but when i replaced mine with 1 1/2 progressive rate springs they were the same size as the stock as far as height. it rode much better with the new springs, but the old ones may have been worn out so im really not sure about the spring rate. but the Syspension techniques springs would be recomended by me if replacement is required. jdawg
--- In ascmclaren@yahoogroups.com, "ascsbr <shortwalk@a...>" > > <shortwalk@a...> wrote: > > > Okay, here's a question for ya. When asc lowered our cars, did > they > > > cut the stock springs? Or, did they install specific rate > springs > > or > > > progressive rate? Anyone know the actual spring rates, 800 lb., > 420- > > > 530 lb.,?? Also were the stock shocks changed out? Were any > other > > > mods done to the cars because they were lowered? Like,lower the > > > steering rack, make adjustments to the alignment, etc. Did the > cars > > > come with a camber/castor plates? > > > I ask because with the stock springs, I'm getting a little tired > of > > > hitting bumps and bouncing off the ceiling. It also feels as > though > > > I'm reaching the end of the limit of the shocks on compression. > > With > > > lowered springs should'nt you use specific shocks? Strange > > > Engineering has adjustable struts and shocks at a great price. > > > Anyone try them ?? > > > > > > thanks > > > > > > steve '89 asc/Mclaren #123 blk./tan, 47,000 miles, strut tower > > > brace, camber/castor plates, sub-frame connectors, 3:55 rear > end, > > > Tremac T5Z SHD 5 speed tranny, Flowmaster Delta Force catbacks, > > > Steeda Tri-ax shifter, 4 wheel discs, BFG TA's 225/50/15's. > > > Hibernating in my garage with fresh oil, a full tank of fuel > with > > > Stabil, battery stored inside, 4 coats of Zaino and under a Noah > > > cover. Anxiously awaiting spring. Current temp in Lake St.Croix > > > Beach, Mn. -9 below zero...........................sr
