2049    <<    Message Index    >>    2051
Number: 2050
Date: Thu Feb 20, 2003  3:15 pm
Subject: Re: [ASC McLaren ] Re: 85 Coupe Speedometer
The 140 speedometer was sourced from Ford Motorsport and it wasn't available
from them until sometime in 1985.
>From a manufacturing standpoint, it probably didn't make sense to put them
into the car as standard equipment until the start of 1986 production when
they could include it in the final costs of the car, retail from Ford
Motorsport at the time was $94.45.
I wonder though if they did offer it as a mid-year stand alone option to the
dealers, maybe Sandy will be able to confirm or deny this though.
Brent
Sent: Thursday, February 20, 2003 12:21 AM
Subject: [ASC McLaren ] Re: 85 Coupe Speedometer> My '85, 607910, had an 85 mph speedo with no evidence of having
> ever been changed. My guess is your car had a 3.08 rearend and has
> been changed to 2.73 or the tire size has gone from the 225/50 tires
> originally installed to a 225/60 which could also cause the
> difference that you noted. Different transmissions could also
> explain your difference. Just changing the speedo head would not
> make a difference in noted speed.
> Your door tag will identify what axle ratio was installed from the
> factory. A 2.73 Traction-Lok will have a code of "M" and a 3.08
> Traction-Lok will have a code of "Z". A tag attached to the rear
> cover of the differential will have a code of 2L73 for a 2.73 and a
> code of 3L08 for a 3.08 ratio.
> Tom S.
> <negusm@y...> wrote:
> > The 1985 coupes were supposed to have 140MPH speedos, right? Mine
> > has the 85MPH variety but has always been 7-8MPH off (registers
> too
> > low, I have to add 7-8mph to get the right speed).
> > I'm wondering if the 85 speedo is definitely wrong, which is odd
> to
> > me since why would anyone replace a 140 with an 85 or its
> possible,
> > the 85 speedo is right, but I have the wrong rearend gears. We
> > never found a tag on the rearend to tell us what was supposed to
> be
> > in there...I have a feeling that the previous owner who raced it a
> > little, may have switched gears (or kept the 140MPH speedo?).
> > We had to replace the rearend gears because they shredded but we
> > can't remember exactly what went back in. I beleive it was the
> same
> > as that were in it since the speedo discrepency didn't change.
> > Would higher or lower gears make the reading go + or -?
> > I bought a Ford 140MPH speedo to go back in this car and figured
> > that I would get the speedo gears all worked out so it read right
> > but its always been an odd curiosity I have never solved.
> > When I get back up there I'll talk to the previous owner and ask
> him
> > if he fiddled much with the car. He only owned it a short time
> > after buying it from Florida before he moved on to (or fell in
> love
> > with) SVOs.
2051 Re: 85 Coupe Speedometer jdawg <jdawg@e...> ecstacycustomz2000 Thu  2/20/2003   6 KB
