2050    <<    Message Index    >>    2052
Number: 2051
Date: Thu Feb 20, 2003  3:30 pm
Subject: [ASC McLaren ] Re: 85 Coupe Speedometer
my 85 rag came with a 140 speedo, and is listed ion the invoice as
an option, not factory equip. however with all the mods i have
done (new rear end, tranny, tires, etc) it is nowhere near right
either. you can get a new gear for the rear of the speedo which
will correct the difference. but you must find out the true
difference. it cant be 7-8 miles off, is it reading when your
stopped? i didnt think so. a speedo will be off a percentage of
miles per mile. like it may be off 1 mile for ever 10 miles on the
speedo. so if your going 60 your really going 54 if its reading
slow. once you figure out the corect ratio you can fix the problem
jdawg
> The 140 speedometer was sourced from Ford Motorsport and it wasn't
available
> from them until sometime in 1985.
> >From a manufacturing standpoint, it probably didn't make sense to
put them
> into the car as standard equipment until the start of 1986
production when
> they could include it in the final costs of the car, retail from
Ford
> Motorsport at the time was $94.45.
> I wonder though if they did offer it as a mid-year stand alone
option to the
> dealers, maybe Sandy will be able to confirm or deny this though.
> Brent
> From: <tkm654@c...>
> Sent: Thursday, February 20, 2003 12:21 AM
> > My '85, 607910, had an 85 mph speedo with no evidence of having
> > ever been changed. My guess is your car had a 3.08 rearend and
has
> > been changed to 2.73 or the tire size has gone from the 225/50
tires
> > originally installed to a 225/60 which could also cause the
> > difference that you noted. Different transmissions could also
> > explain your difference. Just changing the speedo head would not
> > make a difference in noted speed.
> > Your door tag will identify what axle ratio was installed from
> > factory. A 2.73 Traction-Lok will have a code of "M" and a 3.08
> > Traction-Lok will have a code of "Z". A tag attached to the rear
> > cover of the differential will have a code of 2L73 for a 2.73
and a
> > code of 3L08 for a 3.08 ratio.
> > Tom S.
> > <negusm@y...> wrote:
> > > The 1985 coupes were supposed to have 140MPH speedos, right?
Mine
> > > has the 85MPH variety but has always been 7-8MPH off (registers
> > too
> > > low, I have to add 7-8mph to get the right speed).
> > > I'm wondering if the 85 speedo is definitely wrong, which is
odd
> > to
> > > me since why would anyone replace a 140 with an 85 or its
> > possible,
> > > the 85 speedo is right, but I have the wrong rearend gears. We
> > > never found a tag on the rearend to tell us what was supposed
> > be
> > > in there...I have a feeling that the previous owner who raced
it a
> > > little, may have switched gears (or kept the 140MPH speedo?).
> > > We had to replace the rearend gears because they shredded but
we
> > > can't remember exactly what went back in. I beleive it was the
> > same
> > > as that were in it since the speedo discrepency didn't change.
> > > Would higher or lower gears make the reading go + or -?
> > > I bought a Ford 140MPH speedo to go back in this car and
figured
> > > that I would get the speedo gears all worked out so it read
right
> > > but its always been an odd curiosity I have never solved.
> > > When I get back up there I'll talk to the previous owner and
ask
> > him
> > > if he fiddled much with the car. He only owned it a short time
> > > after buying it from Florida before he moved on to (or fell in
> > love
> > > with) SVOs.
