2253
2255
Number: 2254
Date: Sat Mar 29, 2003 6:45 pm
Subject: [ASC McLaren ] Re: 1988 "fog" lights in bottom of front bumper.
http://www.corral.net/tech/maintenance/foglights.html
From what I understand, the power to the foglights goes through the
same wiring for the headlights (including the headlight switch).
The stock ford wiring cannot handle this extra current, and many
people have complained about their fog lights going to pot. The
wires will actually heat right up and become brittle over time.
If I were you, once I got them to work, I would never use them again.
> Thanks Kris!
> I have learned the wrong way about undoing bolts that I know
nothing about.
> I saw the nut that you mentioned but could not see anything else
that would allow me to get the light out of the bumper.
> I do appreciate your help!
> Dick at Myrtle Beach.
> From: buddhak
> Sent: Saturday, March 29, 2003 3:21 PM
bumper.
> In order to get to the bulbs, you must remove the entire
housing.
> If you reach under the front airdam to behind it, you will find
a
> nut (is 1/2" if I remember correctly). undo this nut and the
entire
> housing will pull out from the front. From there, push up on
> pressure tab at the bottom of the housing to separate the lens
from
> the basket, then it's just a simple push on the spring clip to
get
> to the bulb. the bulb size is H4.
> Between the foglamp and the mounting hole, there is a spacer
with a
> notch in it. make sure that when you are remounting the housing
> that the notch fits into the groove in the mounting hole for the
> lamps (kinda hard to explain, but if you look at it, you'll see
what
> I mean). thumb tighten the mounting nut and then switch one so
you
> can properly aim your lamps, then tighten with a wrench.
> If the bulbs are still good, then the switch on the dash may
have
> gone out, they do so often. You can pick up a replacement
switch
> from www.stangparts.com . The ASC switch and the Mustang one
are
> exactly the same.
> Hope this helps,
> Kris K.
> New Orleans
<rjohnson67@s...>
> > Since there are no dumb questions......Neither of the lower
> lights, as above, work from the dash switch. Before I get
desperate
> I would like to check the bulbs/lights - but how do I get them
out?
> It would seem that perhaps they unscrew, since I do not see any
> mounting screws, but now is not the time to break something. I
just
> purchased this rascal and love it!
> > Thank ---Dr. Dick at Myrtle Beach, SC.
> ADVERTISEMENT
> the Yahoo! Terms of
Service.
