2296
2298 Number: 2297 From: "jdawg" <jdawg@e...> Date: Wed Apr 9, 2003 6:16 pm Subject: Re: Sorry, to bring this up again....
yes your hole should be din. yes your radio is a two shaft style. your looking for 2 plates, one metal and one wood that matches the dash. the 2 are the same shape. the metal one goes on first. then you put the radio in from the rear of the dash. then the wood plate goes on and then the shaft nuts. when you tigten them the two plates will sandwich against the recessed area of the dash and hold the radio in. then you should put a back strap on for extra suppost and theft prevention. mine was released in march '85 and came with the alpine. if you remove your dash pad you can check and see if it has the factory installed amp in the center hole on the dash. if its an alpine, chances are you sent the wrong one back. im not sure if the kenwoods came with an amp... jdawg
--- In ascmclaren@yahoogroups.com, "negusm" <negusm@y...> wrote: > I was not directing it at you Sandy, I know you may not know, thats > why you haven't posted. I know if you knew you would be the first > one to reply. I was hoping that somebody who had an 1985 or 1986 car > with an original radio could tell me one way or the other how their > radio is setup. > > Since I have nothing to go by any comment/help is appreciated. I > just hate to get a $150 radio from Hank and have no way to mount it. > I'm just trying to get back to stock if I can....I thought I was > almost there. > > -Mike > >
--- In ascmclaren@yahoogroups.com, "negusm" <negusm@y...> wrote: > > > This bugs me... > > > > > I am not ignoring you, I just do NOT know the answer, Sorry > > > > > > > > > > So as you may or may not know...I sent the Alpine radio back to > Hank > > > to get changed to the Kenwood since I thought my car was an > > early '85 > > > which it may not, the Alpine may be more correct for me... > > > > > > ...but anyways...I called Hank asking for the face plate (trim > > plate) > > > for the radio. The Alpine he sent looked just like the asc > > > Brochure...it has posts (dual shaft)...but it didn't come with a > > face > > > plate panel. The dash in my car which I believe is totally > > original > > > is a DIN-style which was new for 1985 and went to 1986. It has a > > > wide opening and won't support a post style radio without at > least > > > some trim plate or something. > > > > > > My question is, was there a DIN style radio that I should ask > Hank > > > for, or was there a face plate used in the DIN opening for the > dual > > > shaft radio? > > > > > > -Mike
