2554    <<    Message Index    >>    2556
Number: 2555
Date: Wed May 7, 2003  11:24 am
Subject: Re: [ASC McLaren ] Can't keep Brent waiting! CHASSIS TYME !
Rear axles can be bent to give specific camber/caster settings Rear
axles aren't PERFECTLY straight in most cases. If you bend the tubes a
certain way and rotate them with longer/shorter control arms in the
Ford Bind-O-Matic rear suspension you can make minute changes.
76 Mercury Capri GHIA / 77 Mercury Capri RSX
http://www.mercurycapri.com
Still working on it!
Date: Tuesday, May 6, 2003 11:57 pm
> Strange, because I actually have the settings!!
> -- In ascmclaren@yahoogroups.com, Tom G <speedracer815@y...> wrote:
> > Sandy I have a couple of problems with this one:
> > > * Modify Caster/Camber of vehicle, both front &
> > > rear...
> > Not possible in the rear. It's a stick axle and caster
> > and camber are fixed.
