2685    <<    Message Index    >>    2687
Number: 2686
Date: Sat May 17, 2003  10:15 pm
Subject: Re: Frantic about a Top Switch
Tony,
I see two solutions. One if the wires are color coated. Maybe
someone in this group can please pull out their switch and tell the
correct order.
Two, and I am no electrician here, do you have a voltmeter? If so
this will tell you which wires are hot then label them. Again if
someone in the group can go clockwise from the 1 o'clock position to
see which wires are hot too (or left to right, top to bottom), it is
a start. If I remember correctly two are for the top motor, two are
for the landau cover, and one is a ground. I can use this
information too because the previous owner of my '88 replaced my
switch with an older capri style, I'd like to convert back.
Hope this helps.
-Nick
--- In ascmclaren@yahoogroups.com, "frd91gt" <frd91gt@y...> wrote:
> So My pull down motor stopped working the other day. So I tested
some
> wires and everything was dead. So I went back to the switch pulled
it
> out and there wasn't any wires hooked up to it at all. I found the
5
> wires but I have no clue where they go. Someone please help.
> -Tony-
2687 Re: Frantic about a Top Switch frd91gt frd91gt Sun  5/18/2003   3 KB
2689 Re: Frantic about a Top Switch Sandy Block cigarsandy Sun  5/18/2003   3 KB
