2724
2726 Number: 2725 From: "negusm" <negusm@y...> Date: Fri May 23, 2003 1:11 am Subject: Re: What's lost is now found...
Oh and one more item...
What do the three DSO codes mean? I figure that the first is for the special build (F0032) to get the right color but what are the other two for? "R0073" and "236780"
--- In ascmclaren@yahoogroups.com, "negusm" <negusm@y...> wrote: > OK, I looked at info for the Mustang GT and I see how things should > line up. > > XP is the color code. For Mustangs it looks to be a two tone option. > AC is blank and the R has a Y value for Radio Delete. > > The tranny decodes to 3 values. 2 is 5 speed manual. BB and BB > represent codes for front and rear springs. > > -Mike > >
--- In ascmclaren@yahoogroups.com, "negusm" <negusm@y...> wrote: > > Actually I thought about where the paint color should show up and > > next to "XP" there is "Exterior Paint Colors". Was "XP" a mark > for > > a "special color" order? Much like the first gen Mustangs having > > an "X" for their color code when they got painted a Tbird color? > > > > So like who's to say this car wasn't white? Or were white coupes > > ordered normally since white could be gotten on the RS (5.0) as > well > > as the GS? This car was probably built too early anyways to be a > > white one. > > > > Also, is there anyplace where it should say what COLOR the > exterior > > of the car should be. The code is 3L for blue but not found > > anywhere on the tag. > > > > Typo for Front GAWR...should be 3131LB > > > > -Mike > > > >
--- In ascmclaren@yahoogroups.com, "negusm" <negusm@y...> wrote: > > > I found the paper door tag for my car...nasty looking but still > > > readable. > > > > > > Here is what it BARELY says... > > > Date: 01/85 > > > Front GAWR: 131LB/966KG > > > GVWR: 4060LB/1841KG > > > REAR GAWR: 1949 LB/884 KG > > > VIN: 1MEBP79M1FF607872 > > > Type: PASSENGER > > > XP > > > DSO: F0032 > > > R0073 > > > 236780 > > > Body: 61D > > > VR: <blank> > > > MLDG: <blank> (however maybe XP?) > > > > > > The XP that is beneath "PASSENGER" for "Type" is directly above > > > MLDG. Maybe it was put on the wrong line? > > > > > > Int. Trim: PA > > > > > > There is a Y half way between "A/C" and "R". My guess would be > > that > > > the Y is YES for A/C. > > > > > > There is an M half way between "S" and "AX". My guess is that > it > > is > > > for the axle. (poop, I was hoping for the 3.08 and not the 2.73) > > > > > > TR: 2BBBB > > > > > > I guess TR would stand for transmission but "2BBBB" seems like > an > > > odd code for a tranny. > > > > > > -Mike
