2798    <<    Message Index    >>    2800
Number: 2799
Date: Thu May 29, 2003  8:38 am
Subject: Re: [ASC McLaren ] Those mysterious 1984s
Its all about the 25 ascMcLaren Coupes that were built in 1984.
(1984-1986=Capri)
--- In ascmclaren@yahoogroups.com, ram_page97 <no_reply@y...> wrote:
> Sorry if this seems out of left field, but I cant for the life of me
> figure out what it is that is being discussed here. Are these 84
> Capris, McLarens, Mustangs or what?? Sorry, but I cant find any
> threads leading up to this post. Any direction would be
appreciated.
> I have been a lurker for a while, since I love these cars but dont
> yet have one. I have actually been hanging onto the Collectible Car
> Magazine that Sandy wrote an article for almost 10 years ago.
Thanks
> and everyone, keep up the good work.
> > Just a side note here. The roller lifter blocks are different due
> to the
> > taller lifter bores it's true but... People make them work just
fine in
> > older blocks all the time. Most lateral force on a lifter is at
> base.
> > (in a roller there's not much even there)
> > Oh and with the B303 and ported heads you could be well on your
way to
> > 225HP. I'm sure the carb was adjusted too! The exhaust port of
> stock ford
> > heads is terrible! Literally choking the flow characteristics.
> Even the
> > coveted E7TE's of the later years had this same problem. My 85
> coupe smoked
> > em' through second with just ported E7's flowmasters and a
performer
> > manifold.
> > From: "James Gibat-Thoroski" <mercurycapri@c...>
> > To: <ascmclaren@yahoogroups.com>
> > Sent: Wednesday, May 28, 2003 11:52 AM
> > > What's interesting is that it has a B-303 cam in an 1984.
Hydraulic
> > > roller cams/lifters didn't get introduced till 1985. Did they
use
> 1985
> > > blocks in these 1984 cars, or special lifters in an 84 block?
> > > 76 Mercury Capri GHIA / 77 Mercury Capri RSX
> > > http://www.mercurycapri.com
> > > Still working on it!
> > > From: lxfiveoh@a...
> > > Date: Wednesday, May 28, 2003 10:48 am
> > > > Cool. I had never heard of such a car, and I am a self-
proclaimed
> > > > Fox-Mustang
> > > > NUT! :-) I love to hear about rare and unusual Fox-bodies!
> > > > However, I doubt that they made over 225 horsepower.
Remember,
> > > > those 1984 cars
> > > > started with 175. I think it would take a little more than
worked
> > > > stock heads,
> > > > exhaust and a B-303 cam to add 50hp.
> > > > Sandy, would you happen to know of the whereabouts of any of
these
> > > > '84's? :-)
> > > > Nelson
> > > > 1990 Mustang LX 5.0
> > > > http://fiveoh.homestead.com
> > > > > The Valve chambers were
> > > > > enlarged, and housed larger valves, with prototype
springs. The
> > > > > breathing was opened up by means unknown. The 302 was
massaged
> > > > by
> > > > > FORD at Dearborn, and had a B-303 Cam and some cars had
ported
> > > > heads.
> > > > > The exhaust was different. 3" tailpipe width and different
> > > > headers.
> > > > > The car's hood lacked the "vents" and instead had scoops
that
> > > > were
> > > > > cut into the hood, NASA-style. There was the radar
detector we
> > > > have,
> > > > > but it was built INTO the glove box door. Actually, the
unit
> > > > sat
> > > > > inside the glove box, and the door had a cutout with the
> > > > faceplate
> > > > > appearing thru the closed door, flush with the closed
door. The
> > > > > tranny had Hurst linkage and shifter. The axle ratio was
upped
> > > > to
> > > > > 3.08.:1 from 2.73:1. The shift points were sharper and more
> > > > > pronounced. They were all Ford's Deep Cadet Blue Metallic,
with
> > > > the
> > > > > Popsicle Orange striping/Decals/Logos & rims.
> > > > > All 25 were campaigned in & around Detroit Michigan and
> > > > ultimaltly
> > > > > sold in Michigan area, as USED cars.
> > > > > I have been privedged to see 1 in person. They
were //~HOT~\\ !!
> > > > > Again, NOT all had ALL of the above....most did.
> > > > > Then the bean counters arrived at the party.....and never
> > > > brought the
> > > > > beans !
> > > > > Okay?
> > > > > S A N D Y
2800 Re: Those mysterious 1984s negusm negusm Thu  5/29/2003   6 KB
