3199    <<    Message Index    >>    3201
Number: 3200
Date: Thu Jul 31, 2003  5:59 pm
Subject: Re: Please help me I'm new!!
you can use the trunk pull down motor out of a caddy. there is also
a switch in the trunk that prevents the 2 from being operated at the
same time, which would cause a serious bind... check to make sure
that switch is active before you go further. i have switched my
pull down motor out twice, the last time i went to the junk yard i
bought 3 motors just in case.
jdawg
--- In ascmclaren@yahoogroups.com, "gmuffb" <gmuffb@h...> wrote:
> I just bought a 89. The top won't work. The tonneau cover will
> release and close just fine. But the release for the actual top
> won't work. I took the motor out. I can hear the motor running,
but
> the gears won't spin, so the top won't release. I really don't
want
> to pay $300 to have the motor rebuilt. I spoke with the man from
> this website: www.ascmclaren.com. He wanted that much to rebuild
it.
> Do I have any other options??? Thank You.
3202 Re: Please help me I'm new!! gmuffb gmuffb Fri  8/1/2003
