3409
3411
Number: 3410
Date: Sat Aug 30, 2003 11:07 am
I have listed in file "ascMcLaren Colors.txt" in the "files" section:
7N > Dark Shadow Blue Metallic of 1987 & 1988 Mustang
This was from one of your previous posts that I had put in the files
section. Is this also coupe color because you didn't list it in your
last post?
I put the extra color info in the "ascMcLaren Colors.txt" file and
the striping info in the "ascMcLaren Coupe Stripes and Logos.txt"
file. Both are located in the files section. I made sure I added
in all the interesting tidbits that weren't there already.
> Been some talk on here recently regarding paint colors for our
> beloved coupes. Post this to the Database if you'd like!
> COUPE COLORS
> 1984:
> Ford Code 5C - "Dark Cadet Blue Metallic"
> Ditzler Mix Code 3588
> 1985:
> Ford Code 3L - "Dark Blue Metallic"
> Ditzler Mix Code 3171
> Ford Code 9L - "Oxford White"
> Ditzler Mix Code 3620
> 1986:
> Ford Code 7B - "Shadow Blue Metallic"
> Ditzler Mix Code 3865
> Ford Code 1C - "Raven Black"
> Ditzler Mix Code 9000
> Ford Code 1D - "Smoke Metallic" (Med/Dk. Grey)
> Ditzler Mix Code 3842
> Ford Code 1E - "Silver Metallic"
> Ditzler Mix Code 3621
> ascMcLaren felt the strong need to re-name a few of these paints.
> All 3 model-years ascMcLaren referred to the BLUE as "Midnight
Blue"
> and the Smoke Metallic was called Charcoal Grey Metallic and the
> Silver was called Platinum Silver Metallic.
> ABSOLUTELY POSITIVELY NO OTHER COLOR ascMcLAREN COUPES WERE EVER
MADE!
> It should also be noted that the Shadow Blue Metallic and the
Silver
> Metallic were NOT available on the EuroCoupes!! EuroCoupes were
ONLY
> available in the white, the black or the Smoke Grey.
> Full Packaged Coupes offered striping and logo decals in:
> "Popsicle Orange"
> "Raven Black"
> "Platinum Silver"
> IF IF IF IF the ordering dealer did NOT specify the color for the
> decals, ascMcLaren installed the Popsicle Orange on the blue, grey
> and white cars. The Raven Black cars got the Platinum Silver
> striping/logos and the Platinum silver cars got the Raven Black
> Striping.
> However, dealer/customer could order ANY stripe color on any paint
> color by making THAT known. I have located a couple of Raven
Black
> cars with the Popcicle Orange striping and a Smoke Metallic car
with
> Platinum Silver Striping as well as an Oxford White car with
Platinum
> silver Striping. Have also located a F.P. car with NO striping,
nor
> logos EVER, and a handful of blue cars with Platinum Silver
striping.
