That is the correct way Mike. The piece I got off of another car almost made it seem that there were preexisting holes in the strip, but the new strip I have is without holes. The screws or rivits were about 4 inches apart on one car, and a hair more on mine. I will check both strips to see how far apart the holes are. As for the rear strip, can you post a pic of that? Does Hank carry it?
--- In ascmclaren@yahoogroups.com, "negusm" <negusm@y...> wrote: > OK, from what I have seen and the diagram Hank sent me...you can ask > Hank to send the diagram to you. > > First off, if your bumper cover an RS or GS bumper cover. You need > the GS bumper cover to do it right. The GS bumper cover gets cut out > from about 1" below the belt moulding line on the top and about 1" > from the edges. I think the original GS cover actually survived on > my car and we will use it as a template. I could try and get a pic > of it if you need it. > > The thin rubber finishing strip whould be in 2 pieces. One piece > (inner) slides in the other one (outer). > > Somebody please correct me if I'm wrong, it's been a while since I > saw the diagram and I'm sort of guessing at this...but I think that > the rivets that hold the air dam on go first through the (outer) > finishing strip, then the air dam, then the bumper cover. Then you > put the inner piece of the finishing strip in the outer piece to > cover the rivets. > > Fom what Sandy says, the FRONT finishing strip whould be left black. > The REAR finishing strip (which is 1 piece, for looks only) is > painted blue. > > -Mike > >
--- In ascmclaren@yahoogroups.com, "Sandy Block" <cigarsandy@c...> > wrote: > > Interesting question, and I wish I knew the answer for you. Mine's > > down in storage for the coming winter, so I can't just run outside > & > > look at it for you. From washing & waxing the car, I seem to > recall > > that it's on very tight - or tighter than I would expect if it were > > just pressed on. It is very rigid. If I get down there, I'll take > a > > closer look at it & let you know. > > > > S A N D Y > > Life is too short to know Everything! > > > > > >
--- In ascmclaren@yahoogroups.com, Tom G <speedracer815@y...> wrote: > > > My Coupe came with a broken RS airdam. I decided to > > > put the correct one back on rather than trying to fix > > > a part that isn't correct anyway. > > > > > > I bought a NOS airdam from Hank, along with the rubber > > > trim strip. I might eventually buy the fog lights from > > > him too, we'll see. > > > > > > My question is, how does the rubber go on? Does it > > > just press on over the screw heads or are there > > > special clips for it? Either way I guess I'll have to > > > search out some pretty specific hardware. > > > > > > Thanks, > > > Tom Gentry > > > Life is too short for a chinless Coupe. > > > > > > __________________________________ > > > > > > > > > http://sitebuilder.yahoo.com
