OK, from what I have seen and the diagram Hank sent me...you can ask Hank to send the diagram to you.
First off, if your bumper cover an RS or GS bumper cover. You need the GS bumper cover to do it right. The GS bumper cover gets cut out from about 1" below the belt moulding line on the top and about 1" from the edges. I think the original GS cover actually survived on my car and we will use it as a template. I could try and get a pic of it if you need it.
The thin rubber finishing strip whould be in 2 pieces. One piece (inner) slides in the other one (outer).
Somebody please correct me if I'm wrong, it's been a while since I saw the diagram and I'm sort of guessing at this...but I think that the rivets that hold the air dam on go first through the (outer) finishing strip, then the air dam, then the bumper cover. Then you put the inner piece of the finishing strip in the outer piece to cover the rivets.
Fom what Sandy says, the FRONT finishing strip whould be left black. The REAR finishing strip (which is 1 piece, for looks only) is painted blue.
--- In ascmclaren@yahoogroups.com, "Sandy Block" <cigarsandy@c...> wrote: > Interesting question, and I wish I knew the answer for you. Mine's > down in storage for the coming winter, so I can't just run outside & > look at it for you. From washing & waxing the car, I seem to recall > that it's on very tight - or tighter than I would expect if it were > just pressed on. It is very rigid. If I get down there, I'll take a > closer look at it & let you know. > > S A N D Y > Life is too short to know Everything! > > >
--- In ascmclaren@yahoogroups.com, Tom G <speedracer815@y...> wrote: > > My Coupe came with a broken RS airdam. I decided to > > put the correct one back on rather than trying to fix > > a part that isn't correct anyway. > > > > I bought a NOS airdam from Hank, along with the rubber > > trim strip. I might eventually buy the fog lights from > > him too, we'll see. > > > > My question is, how does the rubber go on? Does it > > just press on over the screw heads or are there > > special clips for it? Either way I guess I'll have to > > search out some pretty specific hardware. > > > > Thanks, > > Tom Gentry > > Life is too short for a chinless Coupe. > > > > __________________________________ > > > > > > http://sitebuilder.yahoo.com
