3606    <<    Message Index    >>    3608
Number: 3607
Date: Tue Sep 23, 2003  3:05 pm
Subject: [ASC McLaren ] Re: Front Air Dam Help
I hear ya, My car had some JCW POS on it which didn't handle any
abuse at all.
Here is a pic of my old bumper cover. You can almost see the two
sets of holes. One where the original air dam was and where they
tact on the crappy one.
http://www.ascmclarencoupe.com/Before/BumperDetails2.jpg
Anyhow, I think that's the way the coevr is supposed to be cut.
Maybe its more like 4" at the top now that I look at the picture.
> Tom,
> My car also "lost" the original air-dam and came with a VERY cheap
looking
> aftermarket "RS" look-a-like air-dam installed over the correct GS
bumper
> cover.
> I have seen at least three other Coupes that have suffered from the
same
> fate as mine running, around with an RS front end looking for or
hiding
> their true identity.
> My best guess is the correct front air-dam was too much money for
the owner
> at the time or they didn't know where to obtain one.
> In my cars case, it appeared to be the former since the owner
didn't even
> use a factory Mercury one and went with the "cheap" imitation.
> In any case, check behind the installed air-dam and you might be
lucky to
> find the correct "trimmed" GS bumper cover as Mike had described.
> Mike, I believe your detailed description is absolutely correct.
> Brent
> Sent: Tuesday, September 23, 2003 12:49 PM
> OK, from what I have seen and the diagram Hank sent me...you can ask
> Hank to send the diagram to you.
> First off, if your bumper cover an RS or GS bumper cover. You need
> the GS bumper cover to do it right. The GS bumper cover gets cut
out
> from about 1" below the belt moulding line on the top and about 1"
> from the edges. I think the original GS cover actually survived on
> my car and we will use it as a template. I could try and get a pic
> of it if you need it.
> The thin rubber finishing strip whould be in 2 pieces. One piece
> (inner) slides in the other one (outer).
> Somebody please correct me if I'm wrong, it's been a while since I
> saw the diagram and I'm sort of guessing at this...but I think that
> the rivets that hold the air dam on go first through the (outer)
> finishing strip, then the air dam, then the bumper cover. Then you
> put the inner piece of the finishing strip in the outer piece to
> cover the rivets.
> Fom what Sandy says, the FRONT finishing strip whould be left black.
> The REAR finishing strip (which is 1 piece, for looks only) is
> painted blue.
> > Interesting question, and I wish I knew the answer for you.
Mine's
> > down in storage for the coming winter, so I can't just run outside
> > look at it for you. From washing & waxing the car, I seem to
> recall
> > that it's on very tight - or tighter than I would expect if it
were
> > just pressed on. It is very rigid. If I get down there, I'll
take
> a
> > closer look at it & let you know.
> > S A N D Y
> > Life is too short to know Everything!
> > > My Coupe came with a broken RS airdam. I decided to
> > > put the correct one back on rather than trying to fix
> > > a part that isn't correct anyway.
> > > I bought a NOS airdam from Hank, along with the rubber
> > > trim strip. I might eventually buy the fog lights from
> > > him too, we'll see.
> > > My question is, how does the rubber go on? Does it
> > > just press on over the screw heads or are there
> > > special clips for it? Either way I guess I'll have to
> > > search out some pretty specific hardware.
> > > Thanks,
> > > Tom Gentry
> > > Life is too short for a chinless Coupe.
> > > __________________________________
> > > > > > > > > http://sitebuilder.yahoo.com
