3748    <<    Message Index    >>    3750
Number: 3749
Date: Thu Oct 9, 2003  10:42 am
Subject: Tonneau pull down
Tonneau pull down
I've got an '86 McLaren. The tonneau has ceased to pull down on its own.
(I've never had to push the switch down, as the pull-down sequence was
triggered by pushing down on the tonneau like A Caddy trunk).
Consequently, I have hot-wired the battery off my cordless drill with
alligator clips to bypass the wiring to the motor and get the top
secured. The motor is fine. The relay seems OK as I have manually
operated the points to try and remedy the situation. Does anyone have
a wiring diagram for this system? I fear I have a short, but am not
sure of what wires should be hot and where they terminate. Thanks.
3750 Re: Tonneau pull down Jeff Burgy cobrajeff_1965 Thu  10/9/2003
3751 Re: Tonneau pull down Sandy Block cigarsandy Thu  10/9/2003
